Proving Logarithm Equations: 1/log3a + 1/log4a = 1/log12a
  • Thread starter Thread starter ElementUser
    Logarithm
The discussion centers on proving the logarithmic equation 1/log3a + 1/log4a = 1/log12a. Participants suggest using a common logarithmic base to simplify the left side of the equation, specifically converting to log base 12. One user initially struggles with adding logarithms of different bases but finds clarity after receiving advice to convert all logs to a single base. The conversation highlights the importance of understanding logarithmic properties and the utility of consistent bases in solving such equations. Ultimately, the problem is resolved through the suggested method, demonstrating the simplicity of the solution.
ElementUser
Prove:
ay=x
Logarithms rules (addition, subtraction, power, etc.)
logax=logbx/logba
Left Side:
1/log3a + 1/log4a
=log3a+log4a/log12a (via common denominator)
The problem is how to add logarithms with different bases. I tried converting the log3a to log4a (I get log4a/log43). After that, I subbed it back into the equation.
=log4a/log43+log4a
But I don't think that gets me anywhere...
Right side still remains the same (1/log12a)
Any help is appreciated! Thanks in advance :).
P.S. What program do people use to make their equations look so neat (the fraction looks real - ex. 1/4 really looks like 1 (horizontal line) 4)?
Let's just convert everything to a single log base, like log_12. E.g. log_3(a)=log_12(a)/log_12(3).
Oh, wow. Sigh, I hate it when you take the wrong approach in proving Left Side equals Right Side.
Thanks for the help! Can't believe it was so simple after your suggestion :).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
