Proofs of Logarithms: Proving Equality of a and b
In summary, you can use the normal rule for a product in the exponent to get (log_{a}b)(log_{b}a) =1.
thomasrules
243
Can't start:
[tex](log_{a}b)(log_{b}a) =1[/tex]
Are you to prove that one?
Note that:
[tex]a^{\log_{a}(b)*\log_{b}(a)}=(a^{\log_{a}(b)})^{\log_{b}(a)}[/tex]
Can you continue?
how'd u get that
courtrigrad said:
You know that [tex] a^{\log_{a}(b)} = a [/tex].
how'd u get [tex] a^{\log_{a}(b)} = a [/tex].
It should be [tex] a^{\log_{a}(b)} = b [/tex]. My fault.
i'm sorry but i don't even understand that step from the original to that
You get [tex] a^{\log_{a}(b)*\log_{b}(a)} = a^{1} [/tex] therefore [tex] (log_{a}b)(log_{b}a) =1 [/tex]. Basically, you start with the base [tex] a [/tex] and raise it to the respective powers on the left and right hand side of the equation. You could have used [tex] b [/tex] as the base instead.
Also [tex] a^{\log_{a}(b)} = b [/tex]. Look at an example. [tex] 10^{\log_{10}(100)} = 10^{2} = 100 = b [/tex]
so then:
[tex]log_{a}a=(log_{a}b)(log_{b}a)[/tex]
[tex] \log_{a}a = 1 [/tex] is true. But that is not how I showed that [tex] (\log_{a}b)(\log_{b}a) =1 [/tex]. We have [tex] a^{\log_{a}(b)*\log_{b}(a)} = a^{1} [/tex]. Since the bases of both sides of the equation is [tex] a [/tex], we can equate their exponents to each other. That means [tex] (\log_{a}b)(\log_{b}a) =1 [/tex].
but that's not the proof...
thomasrules said:
how'd u get that
By the normal rule for a product in the exponent.
We can change the base for the second term, which gives
log (base b) a = log (base a ) a / log (base a) b
From there, we can cancel out the term log (base a) b and only log (base a ) a remains, which gives the answer of 1.
Try looking at the 2nd post.
arildno said:
Note that:
Here is the proof that you want. As arildno said, continue this and you will find that [tex](log_{a}b)(log_{b}a) =1[/tex], which is what you said you wanted. All you need to use is the laws of indices, the idea of how logs work and you are done, no joke.
All the best,
The Bob (2004 ©)
thomasrules said:
Can't start:
Get them to the same base. Remember that loga b= x means that b= ax. Now take the logarithm, to base b of both sides of that:
logb b= 1= logb ax= x logb[/sup]a
Since x= loga b, ...
1. What is a proof of logarithms?
A proof of logarithms is a mathematical demonstration that shows how the logarithm of a number can be calculated using a base number. It is used to prove the equality of two logarithmic expressions, where the base and the argument of the logarithm can be different.
2. Why is proving equality of logarithms important?
Proving equality of logarithms is important because it helps us understand the relationship between different logarithmic expressions and their bases. It also allows us to simplify and solve complex logarithmic equations.
3. How do you prove equality of logarithms?
To prove equality of logarithms, you need to use the properties of logarithms and basic algebraic manipulations. These include the power, product, quotient, and change of base properties. By applying these properties, you can transform one logarithmic expression into another, proving their equality.
4. What are the most commonly used properties for proving equality of logarithms?
The most commonly used properties for proving equality of logarithms are the power, product, and quotient properties. These allow you to simplify and transform logarithmic expressions into equivalent forms. The change of base property is also useful when working with logarithms of different bases.
5. Are there any specific steps to follow when proving equality of logarithms?
Yes, there are specific steps to follow when proving equality of logarithms. First, identify the properties that can be used to manipulate the logarithmic expressions. Then, apply these properties to transform one expression into another. Finally, simplify the expressions until they are in their simplest form to show their equality.
