Long life powering of remote Xbee
  • Thread starter Thread starter DanielMRV
    Life
The discussion revolves around optimizing power consumption for a wireless sensor application using Xbee radios. Participants explore various strategies to extend battery life for a standalone sensing device, focusing on sleep modes, power supply efficiency, and transmission methods.
  • One participant suggests using sleep modes for the sensor circuit to minimize power consumption, questioning the sleep current and wake-up time.
  • Another participant mentions having built a circuit that draws only 1uA, allowing a small radio sensor device to last for about a year on two AA batteries.
  • Research into the sleep modes of the Xbee series 2 is noted, with claims that it has a sleep current in the micro amp range, which could help save power.
  • Discussion includes the potential impact of using a DC-DC converter on battery life, with a recommendation for a boost regulator off a 2-cell battery pack to achieve 5V.
  • One participant raises the idea of using "Change-of-State" mode for transmissions, which would only send data when there is a change in state, potentially saving power.
  • Another participant clarifies that they are not using change detection, as they need to take pressure readings at regular intervals instead.
Participants express multiple competing views on the best methods for power management and data transmission, indicating that the discussion remains unresolved regarding the optimal approach.
Limitations include the need for further research into specific sleep currents, the efficiency of power supply options, and the implications of different transmission modes on power consumption.
DanielMRV
I am working on a wireless sensor application at my internship. The sensor network is working, and I am using two Xbee radios, one at the sensing end and the other at the receiving end which routes the information into a central MCU.
The issue is, the sensing radio needs to be standalone and thus will run off of a battery. As of right now, we are seeing about 30-40mA being drawn from the circuit, running off of a 5V power supply that I am acquiring from an Arduino for prototyping convenience. The device needs to be able to operate alone for a long period of time, as we would rather not force our clients to change the battery every couple of weeks.
I have very little knowledge of battery options out there. My question is, what is the best way to power a remote sensing circuit and allow for minimal power consumption so that it may be powered for as long as possible?
Welcome to the PF.
One approach is to "sleep" your sensor circuit for the majority of the time, and only "wake up" to do the sensing and transmit the data for a very short time. This works well if the data are not changing very quickly. What is your sleep current? Can you design the circuit to be off or asleep most of the time? What would be the wake-up time?
To do this, you use a micropower oscillator/counter, which trips the wake-up signal or powers up the circuit. I've built such a circuit that only draws about 1uA, which let's a small radio sensor device last for about a year on two AA batteries...
You can also Google micropower circuits to learn more... :smile:
Welcome to the PF.
I am currently researching sleep modes for the Xbee series 2. Most people claim that it has a sleep current in the micro amp range. Should definitely help save power.
I also need to research efficiency on devices like this: https://www.sparkfun.com/products/8248
I am wondering if using a converter device such as that will have a significant impact on the life of the battery.
Yes, using a switching DC-DC power supply will let you get most of the energy out of the battery, and will generally be more efficient than using a linear regulator. I'd recommend doing a boost regulator off of a 2-cell battery pack to make your 5V. You can use the 2-cell voltage directly (3.2V-1.6V over the life of an alkaline battery) to power the micropower oscillator+counter circuit, and only power up the 5V when the counter expires. (that's for if you are sleeping by powering everything else off)
If you want to use sleep mode for the whole circuit instead, it's best to not run the DC-DC while stuff is asleep -- it just wastes power. In that case, you can stack more batteries and use a low dropout linear regulator, since you only draw your main power infrequently.
I've used "Change-of-State" mode for radio telemetry remotes.
A huge time saving facility is when the system allows 'change of state' transmissions i.e. should an input change from off to on then only does a transmission take place.
Planning Transmission Rates
Are you using Change Detection Mode in your remote radio?
Change detection as the word itself says detects change of state. We can monitor one or more digital I/O pins for change of state. A sample is transmitted whenever this change of state occurs. In change detection sampling, a request is made to send a sample of data when ever there is a change in state at one or more digital I/O pins.
Sampling Data from XBee Radio in Change Detection Mode
  • · Replies 26 ·
  • · Replies 34 ·
