Looking For A Solid Material Light Diffuser - Terminology?
The discussion focuses on finding a solid material that can effectively diffuse light, particularly for a thin bar with a light source at one end. Participants suggest translucent plastics like polypropylene or polyurethane as potential options, and mention that roughening clear plastics can enhance diffusion. There is interest in achieving more precise control over light exitance, which is recognized as a complex task. The conversation also highlights the importance of providing specific application details to better guide material selection. Overall, the quest for suitable terminology and materials for light diffusion remains central to the discussion.
golmschenk
I'm looking for a solid material that will diffuse light throughout it. In particular I would need a thin bar with a light source at one end that will diffuse light to all sides of the bar, however, I don't specifically need a bar as long as the material can be machined. I'm trying to search for some type of material like this, but I guess I really don't know what kind of terminology to be using and I keep ending up finding only cinematography light filter films. If anyone has any idea of the material I'm looking for or just the proper terminology of what I should be searching for let me know. Thanks for your time!
Science news on Phys.org
Do you mean translucent plastics? Polypropylene or polyurethane may work ok:
http://www.professionalplastics.com/
If you need quantitative control of the exitance, that's significantly more complex. Another good trick is to simply roughen the faces of a clear plastic like acrylic (with sandpaper or something).
Thanks, the translucent plastic *might* work. A more quantitative control would definitely be a plus. Even if that means it will be more complex/expensive. What would I want to look for if I were searching for this more complex method?
I know a little about non-imaging optics (of which illumination control is a topic), but all I know is that it's more an art than science.
It would be more helpful (here) if you gave some information about your application.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
