Looking for Intuitive Reasoning Behind Rational Exponents
The discussion revolves around understanding the intuitive reasoning behind rational exponents, specifically in the context of the expression √[3]y·√[5]y². Participants explore how to express this in exponential form, leading to y^(11/15) and ultimately √[15]y¹¹. The conversation highlights the relationship between the index of a radical and the powers of the radicand, emphasizing that √[n]a^m equals a^(m/n). Clarifications are provided on how exponentiation and roots relate, aiming to enhance comprehension of these mathematical concepts. The thread concludes with a participant expressing a desire to deepen their understanding of the explanations given.
DS2C
Solving these seem fairly simple so far. But I don't know why this works. I asked my instructor and she couldn't give me an intuitive reason as to why.
##\sqrt[3]y\cdot\sqrt[5]y^2##
N/A
$$\sqrt[3]y\cdot\sqrt[5]y^2$$
$$y^\frac 1 3\cdot y^\frac 2 5$$
$$y^{11/15}$$
SOLUTION = $$\sqrt[15]y^{11}$$
Why does this work?
You may find this helpful. Scroll to 22-3 if you want information pertinent to your question, but the whole piece is worh reading.
N/A
It kind of depends on what you're looking for by "why" and "intuitive". One simple way to think about exponents that are that are positive integers-- is just the number of times you'd type them into multiply them on your calculator.
So what would be
$$\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)^{15}= \prod_{k=1}^{15} \big(\sqrt[3]y\cdot\sqrt[5]y^2\big) = \big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big)\big(\sqrt[3]y\cdot\sqrt[5]y^2\big) $$
Now use that fact that all these terms are associative and commute -- i.e. get rid of parenthesis and re-arrange terms and simplify this. What do you get?
I can see the equal factor part, but for example, why is the denominator in the exponent the index of the radical and the numerator is the radicands power?
Also, what's that pi symbol looking thing you have there?
## \prod_{k=1}^{15} \big(\sqrt[3]y\cdot\sqrt[5]y^2\big)## literally means the multiplication that I show to the right. Are you going to try to simplify the 15 terms and show what you got?
Given.
Simply changing the notation.
$$y^{11/15}$$
Addition of exponents.
Correct answer.
Why does this work?
You did the work correctly. Which step are you asking about?
I missed this post, thank you. I'll give that a read!
I'm not sure what you mean. Do you mean to simplify it into ##\sqrt[3]y^{15}\cdot\left(\sqrt[5]y^2\right)^{15}##??
FactChecker said:
Given.Simply changing the notation.Addition of exponents.Correct answer.
One of my confusions lies with the relation between the index of a radical and the power of the radicand to the numerator and denominator of it's exponential form. For example,
##\sqrt[n]a^{m}## is equal to ##a^\frac m n##
sort of. note that ##(a)^{15} = (a^3)^5## for the same reason that both involve multiplying by a, 15 times.So you get
## \sqrt[3]y^{15}\cdot\left(\sqrt[5]y^2\right)^{15} = \big(\sqrt[3]y^{3}\big)^5\cdot\left(\sqrt[5]y^2\right)^{15} = \big(\sqrt[3]y^{3}\big)^5\cdot\left(\sqrt[5]y^{30}\right) = \big(\sqrt[3]y^{3}\big)^5\cdot\left(\sqrt[5]y^5 \right)^6 ##now look at that last expression. You have a cube root that you are "undoing" cubing process, and you have a fifth root that you are 'undoing' by raising to the 5th power. Hence this gives:##\big(\sqrt[3]y^{3}\big)^5\cdot\left(\sqrt[5]y^5 \right)^6 = \big(y\big)^5\cdot\left(y \right)^6 = y^5y^6 = y^{11}##so now we have ##y^{11}## is equal to your original expression raised to the 15th. But your end expression raised to the 15th is
##\big(\sqrt[15]y^{11}\big)^{15} = \big(\sqrt[15]y^{15}\big)^{11} = \big(y\big)^{11} = y^{11}##.There's some lingering technical nits about whether or not a mapping is invertible that I won't go into, but you should be able to see that both expressions get you to the same place when you raise to the 15th. And the whole idea behind ##\sqrt[15]## is that you had some number you raised to the 15th power, and now you are trying to recover the number that you originally had. Hopefully this is an intuitive way to look at this.
I don't know if I can help you with intuition on it. I think of them as just different representations of the same operations: ##\sqrt[n]a^{m}## = (am)1/n = am⋅1/n = am/n
You look after intuition for why we write: ##a^{m/n}##?
Then you must first know how this notation is defined and how it relates to roots.
So, let me start with saying that ##a^{1/n}## is defined as the unique number ##x## such that ##x^n = a##, i.e. the number ##\sqrt[n]{a}##. Then, ##(a^{1/n})^m = \sqrt[n]{a}^m = a^{1/n} \dots a^{1/n}##. This is a useful definition as it can be shown it is well defined and it extends the power laws we know from the integers.
Thanks for the responses all. Taking them in as I go. Still working on fully understanding your expalantions. For some reason this concept is coming weirdly to me. Theyre easy to solve, but working on what you're saying to understand the whys.
Think of it this way. If we decide to denote n ##x##'s multiplied together (or ##x## multiplie by itself (n-1) times) then we shall have the two laws ##x^{a}\times x^{b}=x^{\left( a+b\right) }## and ##\left( x^{a}\right) ^{b}=x^{ab}##.
From this we can see that multiplying certain numbers together, can be done using the operation of addition which is easier. And division into subtraction. (This leads to finding a way to change multiplications and divisions of all numbers into easier additions and subtractions which you may or may not yet have done.)
Now for your question start with ##x^{1/n}## . What does "the n-th root mean? It means "the quantity that multiplied by itself (n-1) times gives you ##x##. Now use the above laws to work out what raising ##x^{1/n}## to the n-th power according to the definition gives you.
Likes FactChecker
That Feynman lecture Is cool. I am going to read more.
