Looking out the window of a fast ship
In summary, the pole appears to be 500 light seconds long when viewed from a rear-facing window next to where it is attached, but it is actually only 5 light seconds long.
Taremos
Okay, for the moment, forget about time dilation.
Are the following descriptions accurate if you do not account for time dilation?
I've been going over and over this in my head and I can't figure out why any of these don't make sense.
Setting: A ship going .99c.
Attached to the rear of the ship there is a pole pointing parallel to the direction in which the ship is cruising. The pole is 5 light seconds long. Looking out a rear-facing window which is directly next to where the pole is fastened you see the pole like looking up a tall building from it's base. Even after correcting for the illusion of inflated height caused by standing so close to the base, the pole appears to be 500 light seconds long, not 5 light seconds long.
There is another pole 10 meters long attached perpendicular to the direction of the ship, to the side of the ship. You are able to view this pole from a side-facing window, 10 meters behind where the pole is mounted to the hull. Looking out at it the pole appears to be shorter than it actually is. Also, looking at the portion closest to the hull it looks normal, but as you look at the pole further away from the hull, it appears to be warped so that you see it as if you were looking along at an angle much smaller than the one you are.
Looking at the same pole as mention in 2, you are able to view it from another view port 10 meters away from it. This time the view port is closer to the front of the ship than where the pole is mounted. Looking back at the pole it appears to be much further away and much much smaller than it actually is and the angle at which you see it does not appear correct. It looks like the pole is much further away than 10 meters.
There is yet another pole 5 light seconds in length attached to the hull of the ship. This pole is faceted to the front of the ship, parallel to the direction in which the ship is traveling. Similar to the rear-facing pole, there is a view port right next to the base of this pole. Peering out this port gives you a few of the pole from it's base, but the pole appears much closer than it is and is distorted so that each part of the pole appears to be about half the distance of what it is. It still appears to be 5 light seconds in length, but looking at the tip, the tip it looks as if you are only about 2.5 light seconds from it.
You observe a planet from the ship which is 10 light minutes away and almost directly in front of the ship, the ship will miss it by only a few hundred kilometers. You look upon the planet and judge it to be 10 light minutes away. A minute later you look again, and it appears to be about 9 light minutes away. Another minute passes and it looks about 8 light minutes away.
I didn't have time to read everything but you can't just "forget" about time-dilation. If you do than lots of paradoxs can arrise, and even before that, time dilation comes from the same equations as length contraction so how can you use one but not the other? Whatever conclusions you get to by forgeting about time dilation aren't physics, or anything else that i can think of for that matter.
And in (1), you say that the pole is 5ls long, in which frame?
Here's where you went wrong: there's no such thing as an absolute velocity. Velocities can only be measured relative to nearby objects, or relative to a coordinate chart.
So, let's define some charts:
Let X be an inertial coordinate chart where the ship is going 0.99c forward.
Let S be an inertial coordinate chart where the ship is at rest.
Let W be an inertial coordinate chart where the ship is going 0.99c sideways. (in the direction of the second pole)
You subsequently state a lot of measurements -- but they all have the same problem: you don't specify in which coordinate chart they are measured. Normally, when one describes an object without qualification, they mean how it appears when at rest. I will assume that's what you meant throughout this reply.
No. S sees a 5 light-second long pole. W also sees a 5 light-second long pole. X sees a very, very short pole.
I.e. in terms of what you actually observe, you see a 5 light-second long pole.
No. S sees a straight 10 meter pole. X sees a straight 10 meter pole. W sees a straight, very short pole. The pole is straight in all three coordinate charts; but an observer in X will see a "warped" pole due to the difference in time it takes for the light from different parts of the pole to reach him. But when he corrects for that, he will find the pole is straight. Observers in S and W will see no warping.
I.e. in terms of what you actually observe, you see a straight, 10 meter pole.
Nope. Everything is the same as in 2. You see a straight, 10 meter pole. The pole is always perpendicular to the ship in X, W, and in S (though not in most charts). I don't know for sure, but it's plausible an observer in X might actually see a non-right angle due to light transit time. Observers in S and W will always see a perpendicular angle.
There is absolutely no difference between this pole and the rear pole.
I will assume you meant the planet appears 10 light-minutes away in S's chart. In that case, after k minutes, the planet will appear at a distance of
10 light-minutes - 0.99c * k minutes
So, if my assumption was right, you have this one correct.
Maybe I'm missing something (and frankly, I didn't read past the 2nd case...), but it sounds pretty straightforward to me: a pole attached to your ship isn't moving wrt you, so they all look like they are the "right" size. Time dilation and length contraction don't come into play.
[QUOTE="Hurkyl" about #1]No. S sees a 5 light-second long pole. W also sees a 5 light-second long pole. X sees a very, very short pole.
I.e. in terms of what you actually observe, you see a 5 light-second long pole.[/QUOTE]
Since there's plenty to talk about here, let's start with #1...
I don't understand why that is. Okay, light hits the pole and begins the trip to the view port. The light that is coming from the pole is going 1c, since light always goes 1c regardless of the velocity of the object it is emerging from.
So let's start with light coming from the tip of the pole, a distance of 5 light-seconds away from the ship (1 498 962 290 meters from the ship). The light is traveling at 1c. The ship is traveling in the same direction as the light that will eventually find its way into the view port at the rear at .99c.
If the ship was still (in relation to light), the light would get there 5 second after it left the tip of the pole. But because the ship is moving at .99c in the same direction as the light, the light is only moving at .01c relative to the observer in the ship, thus it takes 500 seconds to get to the observer. Since it took 500 seconds, the light has spread out that much more and it will appear that much further away... 500 light seconds away.
Am I missing something?
Doesn't light move at c relative to all observers.
Matheinste.
When you say "forget time dilation", are you also forgetting about length contraction? Do you just want to know how these things would look in a Newtonian universe? Or are you having doubts that in relativity the pole would appear the same length to observers on the ship regardless of the ship's motion? If you're asking about relativity, then you can't ignore time dilation and length contraction, they are essential to understanding why it looks the same.
Yes.
Relative to you, the observer on board the ship, neither the ship nor the pole is moving. Therefor it takes light just 5 light seconds to reach you from the tip of the pole. This is what Hurkyl meant by frame S. The fact that the ship is moving in a different frame is immaterial to your question.
paw said:
Yes.
But it's still true that all frames must agree on their physical predictions, so you could interpret Taremos' question as a question about how the predictions of the two frames can be consistent. You're certainly free to calculate what the observer on the ship will see using a frame where the ship is moving at 0.99c rather than the ship's rest frame, although it's simpler if you use the rest frame.
Absolutely, but his question was specifically asked in the ship centered frame.
He was asking what the observer on the ship would see using light-signals, but the numbers he used seemed to suggest he wanted to calculate this from the point of view of the frame where the ship was moving at 0.99c.
JesseM said:
He was asking what the observer on the ship would see using light-signals...
Ok. I thought that was what I said. :biggrin:
What the observer on the ship sees with his eyes is a physical question which has nothing to do with what frame you use. You said that "his question was specifically asked in the ship centered frame", but I don't think Taremos said anything to indicate he was using the ship's frame.
I'm not sure what the Original Poster (OP) meant when he said "forget about time dilation".
Also, since he was interested in "what you see", it's possible he was asking about Terrell rotation. There's a FAQ about this and a lot of google hits, too:
http://math.ucr.edu/home/baez/physics/Relativity/SR/penrose.html
I'll quote a brief excerpt, if it's relevant one might want to read the entire article:
People sometimes argue over whether the Lorentz-Fitzgerald contraction is "real" or not. That's a topic for another FAQ entry, but here's a short answer: the contraction can be measured, but the measurement is frame-dependent. Whether that makes it "real" or not has more to do with your choice of words than the physics.
Here we ask a subtly different question. If you take a snapshot of a rapidly moving object, will it look flattened when you develop the film? What is the difference between measuring and photographing? Isn't seeing believing? Not always! When you take a snapshot, you capture the light-rays that hit the film at one instant (in the reference frame of the film). These rays may have left the object at different instants; if the object is moving with respect to the film, then the photograph may give a distorted picture. ...
What is called time dilation and length contraction is simply an effect on light signals between objects that are in relative motion with each other. The proper lengths and times of the objects in question are not affected by relative motion. Only acceleration (and by equivalence spacetime curvature) affects the future rate of accumulation of proper time.
He said "relative to the observer in the ship". I took that to mean in the frame of the ship. If that's not what he meant then all bets are off...
No light signals need to be passed to see the effects of LC ans TD. Just give each observer a grid of rulers and clocks.
You are wrong Daniel, without light signals one cannot measure time dilation and length contraction effects due to objects being in relative motion with each other. But as I said before acceleration (and spacetime curvature) does change the future rate of proper time accumulation for an object.
Feel free to demonstrate I am wrong by showing length contraction or time dilation without light signals by for instance using "chalk marks" on your grid showing the length of the object in relative motion or by directly comparing the difference in elapsed time of two clocks by bringing them together and without any of them ever accelerating or going through curved spacetime. It won't be possible, simply because, what I said before, length contraction and time dilation are effects on the signals between objects in relative motion not effects on the proper values of these objects.
Ok,
Lets say you have one observer (A) who has set up a system of evenly spaced clocks, each with their own observers (who are at rest relative to the clocks), that are all in sync in his frame. Now you have another observer (B) who is moving relative to that system. Observer (B) sets of a firecracker next to clock #1. The observer at clock #1 writes down the time shown on his clock (ta1) and observer B's clock (tb1) when he noticed the explosion. Observer (B) continues on and sets of another firecracker next to clock #2. The observer at clock #2 writes down the time shown on his clock (ta2) and observer B's clock (tb2) when he noticed the explosion. The observers at each clock send their data over to their frames central database there they find that:
ta2-ta1 =/= tb2-tb1
No light signals where needed. And the time it takes for the clock observers to see the explosions is neglegible as the clocks can be placed arbitrarily close.
In the first post he was just talking about what the observer would see, but you're right, in the next post he said "But because the ship is moving at .99c in the same direction as the light, the light is only moving at .01c relative to the observer in the ship", I had missed that part. That statement would be wrong in relativity, since as you say, the light is still moving at c in his frame.
I repeat: there is no such thing as absolute velocity. Phrases like "the ship is travelling" are nonsensical. They only make sense relative to a coordinate chart.
Furthermore, while things like "length of object" or "time measured by a clock" do have 'absolute' values (we call them proper length and proper time), those values are generally not equal to the lengths and times one measures in a coordinate chart.
Incidentally, the part about velocity is also true in classical mechanics. Surely you've done exercises in classical mechanics such as people tossing balls in train cars!
In an inertial coordinate chart where the ship is traveling at 0.99c, the pole will be measured to be 0.71 light-seconds long, and it will take 71 seconds (as measured in this coordinate chart) for a photon to travel from the tip of the pole to the viewport.
But in an inertial coordinate chart where the ship is rest (i.e. in the coordinate chart relative to which you are making measurements), the pole is measured to be 5 light-seconds long, and it will take 5 seconds for the light to travel from the tip of the pole into the viewport.
The photon traveling from the tip of the pole to the rear viewport experiences zero proper time.
daniel_i_l said:
Ok,
ta2-ta1 =/= tb2-tb1
How does that show that observer B's clock runs physically slower than observer A's clock? Note that in your example observer B attended both firecracker events but observer A did not attend any of those events. He simply subtracted readings from two different clocks that were previously correlated by light signals.
Anyway, if you think you know better then feel free to think that length contraction and time dilation are actual effects on the objects in question, it seems that I am certainly not able to convince you otherwise. :smile:
Maybe it will help to think of this in a different way.
Suppose you are standing at the rear viewport, and there is a mirror sitting at the tip of the pole. You shine a flashlight out the rear viewport and start your stopwatch. You will see the reflection when your stopwatch reads 10 seconds.
Everybody in the entire universe will agree that your stopwatch read "0 seconds" when you turned the flashlight on, and that your stopwatch read "10 seconds" when the reflected light beam reaches you.
That is 100% correct! :smile:
I think that I didn't explain myself properly, I'll try again:
I don't think that LC changes the actual length of the object just like TD doesn't physically change the clock. But I also don't think that it just has to do with light signals. Rather, the important reason for TD and LC is the geometry of spacetime, ie: the lorentz metric. With that metric TD and LC are just the outcomes of different observers seeing the events at different "angles". For example:
Let's say you have a point (1,1) on a 2D graph. Someone looking at the graph from an angle will measure different coordinates but will agree on the distance of the point from the line: x^2 + y^2 = d^2
Now since c is constant it can be used to get seconds and meters into the same unit. Let's say that we're measuring everything in meters (so seconds get multiplied by c). If observer A measured 6 meters in time and 2 meters in space between the two points then the total distance of the second explosion from the first one is t^2-x^2 (using the lorentz metric) = 6^2-2^2=36-4=32 meters. Since the second observer B measures the distance in space as 0 but must measure the same total distance in ST then the time that he measures is: t^2 - 0^2 = 32 => t = sqrt(32) < 6.
The only need for the light was to convert time into units of meters in a way that would be the same for all frames. After that it's all in the geometry, different people measuring different coords for the same points (events).
If instead of the lorentz metric, the "normal" (pythagoras) then instead of time dialation, observer B would measure more time than observer A, not less.
1. How does the view from a fast ship differ from a slow ship?
The view from a fast ship will appear to be moving faster and smoother in comparison to a slow ship. The scenery will also change more quickly as the ship travels at a faster speed.
2. Can you see more or less from the window of a fast ship?
You may have the opportunity to see more from the window of a fast ship as it travels at a faster speed and covers more distance in a shorter amount of time. However, this also depends on factors such as weather and visibility.
3. Is it safe to look out the window of a fast ship?
Generally, it is safe to look out the window of a fast ship. However, it is always important to follow safety precautions and listen to instructions from the ship's crew. Additionally, if you are prone to motion sickness, it may be best to limit your time looking out the window.
4. What can you expect to see while looking out the window of a fast ship?
The view from a fast ship can vary greatly depending on the location and route of the ship. You may see vast bodies of water, other ships or boats, coastal landscapes, or even marine life such as dolphins or whales.
5. Are there any benefits to looking out the window of a fast ship?
Looking out the window of a fast ship can provide a unique and exhilarating experience. It can also offer a sense of relaxation and connection with the surrounding environment. Additionally, it can be a great opportunity for photography or simply taking in the beauty of the journey.
