Lorentz Transformation - Proof that t'2 - t'1 >0
The discussion centers on proving that the time difference t'2 - t'1 is greater than or equal to zero using the Lorentz transformation, emphasizing that an effect cannot precede its cause. Participants explore the transformation equations, with one user expressing confusion about the proof's correctness. Another contributor suggests substituting values and using causation conditions to clarify the proof. There is a debate over the appropriateness of manipulating the problem's origin, with differing opinions on whether it aids or complicates the solution process. Ultimately, the conversation highlights the importance of logical reasoning in solving problems related to relativistic physics.
zacl79
A 'cause' occurs at point 1 (x1, t1) and its 'effect' occurs at point 2 (x2, t2) as measured by observer O. Use Lorentz transformation to find t'2 - t'1 as measured by O' and show that t'2 - t'1 >= 0. that is Observer O' can never see the effect before the cause.
I know that is possible to prove this, but just having some difficulty in doing so.
I use:
t'1 = (gamma)(t1 - ux1 /c^2) => goes to zero as X1 and t1 are 0??
t'2 = (gamma)(t2 - ux2 / c^2)
Working through this i get:
t'2 - t'1 = gamma(t2 - ux2 /c^2)
Now i don't think that this is the correct proof that i require.
Any help to where i have gone wrong, or if i am overlooking something would be greatly appreciated.
Thanks
since x2<ct2 as lower than the speed of light, you can substitute this into your equation to get.
ux2/c^2 < uct2/c^2 < t2
hence t2 - ux2 / c^2 > 0
so t'2 - t'1 > 0 also
hi zacl79! :smile:
(try using the X2 icon just above the Reply box :wink:)
you haven't used the causation condition yet :wink:
you can put x1 = t1 = 0, but it's probably better not to mess about with the original question, in case you make a mistake "translating" it back :redface:
I think you should always mess with the question and use logic, if it makes the problem easier to solve. Since the physics is the same in all reference frames it doesn't matter where we assign the origin.
Mr Gibson, please don't advise students to take steps which make it easier to make mistakes, and to lose both time and marks in exams. :redface:
Sorry Tim, but I disagree with this statement. I thought the reasoning for the method was justified. If the student clearly reassigns the origin in their working their result are still valid. In fact I believe this method would save time and lead to less mistakes otherwise I would not have advised it.
You particularly stated that this could lead to error translating it back, and I agree with that statement, but it is not applicable to this problem. You are defining x1, t1 as the origin, no other origin has been defined so there is no need translate back.
Hence I would only understand your objection if the origin had already been defined.
Thanks guys,
Ill give it a go!
