Lorentz Transformation: R_2=R_1^{-1}?
facenian
Let L_w be a Lorentz transformation between to systems that coincide at t=0(paralell axes assumed) and with relative velocity w along x_1. If L_u is the Lorentz transformation when the relative velocity u is in any direcction then we have that L_u=R_2 L_w R_1 where R_2 and R_1 are sapce rotations, R_1 is such that the direction of u and x_1 are the same.
My question is: is it correct that under this circuntances R_2=R_1^{-1}?
I think the answer is yes. It seems straightforward to verify that it holds for the case where u lies along x_2, i.e., the case where the angle theta between the w and u vectors is pi/2. Also, if it holds for rotations by theta in the 1-2 plane, then it also holds for 2theta. The combination of these two facts makes me think that it holds for any rotation in the 1-2 plane, and since the choice of the 1-2 plane is arbitrary, I think it has to hold for any rotation.
[When I previewed the post above, I saw some of the math rendered incorrectly. The first reference to theta is rendered by some other, unrelated math, (1-epsilon)c. I remember that this is a known bug in the software used by PF, but I don't remember if there is any way to fix it.]
[Later edit: it now seems to be rendered correctly.]
[Gah, now it's rendering incorrectly again, after I made another edit. I'll just remove all the math.]
yes there seems to problems when you write in latex that's why I don't use it anymore. Thank you for your answer
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
