Loss of momentum in supposedly isolated inelastic collsion?
The discussion centers on a lab experiment involving an inelastic collision between two gliders on an air track, where the calculated momentum before and after the collision appears inconsistent. The participant calculated initial momentum as .072 N*s and final momentum as .028 N*s, indicating a loss of momentum. They question whether this discrepancy could be due to energy lost in vibrations during the impact. The participant notes that, given equal masses, the final velocity should be half of the initial velocity of the moving glider. The conversation highlights the importance of accurate velocity measurements in momentum calculations.
bravoghost
I may have made a mistake in calculating, but I just finished lab homework where my calculated momentum was different before and after an inelastic collsion. Is it possible that momentum was lost in the vibration of the impact or something?
The experiment placed two gliders on a level air track (isolated system) and one glider was pushed into a second one that was station.
here are my values:
m for both gliders = .2014 kg
v1i = .3576 m/s (after the push)
v2i = 0.000 m/s
vf = .0716 m/s
with all that subbed into the conservation of momentum equation for inelastic collsions, i got .072 N*s for before the collision, and .028 N*s for after. That doesn't =0!
It looks like an error in one of the velocities. Since both masses are the same, the final velocity immediately after impact should be half the velocity of the moving object just before impact.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
