Troubleshooting Low Pump Discharge: Tips to Boost Speed and Output
  • Thread starter Thread starter prasan_y2k
    Discharge Pump
The low discharge output of the 12v DC rotary vane pump, which is significantly below its maximum capacity, is likely due to excessive voltage drop caused by using wires that are too thin and too long. To resolve this issue, it's recommended to refer to a wire sizing table to ensure that the wire gauge is appropriate for a 20 amp draw, maintaining a voltage drop of no more than 3%. Upgrading to thicker wires can help improve the pump's performance and increase the discharge rate. Additionally, ensuring proper connections and minimizing any potential obstructions in the system may further enhance output. Addressing these electrical factors is crucial for optimizing pump efficiency.
prasan_y2k
I have a 12v DC (rotary vane type) pump that is connected to a 12v auxillary battery. The battery is 12vDC 70Ah and it charges itself with the truck's alternator, which is 12 volts, 35 amps. the pump is 1/4 hp, and it draws 20 amps max. The problem is, the discharge output of the pump is very low(8-10lpm), whereas the pump is designed to have a max discharge of upto 57lpm.
What is the reason of low discharge?
Is there any way to increase the speed of the pump so that the discharge rate is increased?
Most likely, the low performance is because of excessive voltage drop in the wire. Too thin wires, combined with too long wires. Here is a table you can use to size wire so that the voltage drop is never more than 3%. Look up 20 amps, your required length, and the table gives the required wire gauge.
246358
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
