Low Voltage AC-AC or AC-DC Step Up
11 replies · 3K views · last reply
BabyHueyTAW
Ok, So my generator is producing ~1.5VAC. I need to step that up via transformer to no less than 5VAC max of 20VAC.
Ideas or links to components I can use?
Google search DIY transfomer. There are many sites offering adivce, lists of componenets, and sometimes calcuators.
a doorbell transformer ?
Think that would work? I have this set up, Need 5VAC to energize my conversion system, minimal current draw, maybe 5ma total.
Shown, is my AC/DC to DC step down (left) and my DC-DC step up.
Need to bump the input from my generator outputting 1.5VAC.
**End goal is charge a portable cell phone battery pack**
Two small electronics modules on a black board: a yellow step-down converter with a potentiometer and red LED display on the left, and a clear-cased DC-DC boost module with a blue LCD on the right, wired together with red, black and yellow leads.
  • Two small electronics modules on a black board: a yellow step-down converter with a potentiometer and red LED display on the left, and a clear-cased DC-DC boost module with a blue LCD on the right, wired together with red, black and yellow leads.
Ahh! I think you're onto something there!
so a doorbell XFMR 120-16 is like a 7.5:1 ratio
So if i run it reverse, my 1.5 would become close to 12 out!
Or am I off the mark?
Black outline icon of a thumbs-up hand gesture on a white background.
  • Black outline icon of a thumbs-up hand gesture on a white background.
Perhaps I am missing something but to me it looks like you want to create energy out of nothing.
Sounds like his generator (from microhydro maybe?) generates a pretty low AC voltage, and he needs to step it up efficiently before running his DC-DC power converter. Seems okay from an overall energy standpoint.
At what frequency or range of frequencies?
great observation.
i'd completely forgot his generator has up&down motion not round& round.
So frequency might be too low for a household transformer.
A 16 volt transformer will support 1.6 volts down to about 6 hz.
Volts per Hertz ratio is a constant for any particular core.
Probably my understanding of what VAC exactly means is wrong. Is it V AC (voltage of active current) or VA*Cos(φ) (power)? Or even something else?
Volts AC, or AC volts. Alternating current.
Edit: As opposed to VDC, or DC Volts.
