Can You Correctly Lower Tensor Indices Using the Metric Tensor?
  • Thread starter Thread starter beans73
    Indices Tensors
beans73
I have a tensor X^{μ\nu} and I want to make this into X_{μ\nu}. Can I do this by simply saying X_{μ\nu}=\eta_{μ\nu}\eta_{μ\nu} X^{μ\nu} ??
You have the right idea, but your indices are incorrect (it's ambiguous which indices are to be contracted with which other indices). Try introducing some new indices for the contracted ones, see if you can make it unambiguous.
for example, you could write:
V^{\mu} = \eta^{\mu \nu} V_{\nu}
Which makes it clear which index of eta is contracted, and which isn't. In this case, eta is symmetric so it doesn't really matter, but for a general tensor with two or more indices it does matter.
To explain why it's ambiguous, consider this:
Does X_{μ\nu}=\eta_{μ\nu}\eta_{μ\nu} X^{μ\nu} mean X_{μ\nu}=\eta_{μ\nu}(\eta_{μ\nu} X^{μ\nu})? In that case you would get a tensor proportional to eta. This is obviously not what you were thinking, but if someone saw that expression and didn't know that you were trying to make X_{\mu\nu}, they might think you meant to make a tensor proportional to eta.
So just a good rule of thumb, never repeat an index unless it is supposed to be summed.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
