Lumens and photon flux density
Calculating photon flux density from lumens produced by a fluorescent tube is not straightforward. It requires knowledge of the spectral power distribution (SPD) of the light and its radiation pattern. The SPD can typically be obtained, while the radiation pattern may need to be estimated. Without these specifics, an accurate calculation cannot be made. Understanding these factors is essential for precise measurements of photon flux density.
DMS-Aberdeen
Is there a simple way of calculating photon flux density from the lumens produced by a fluorescent tube?
Not exactly. You need to know the spectrum (spectral power distribution, or SPD) of the fluorescent light, and the radiation pattern. The SPD should be available, and you could estimate the radiation pattern.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
