Lyapunov exponents of a damped, driven harmonic oscillator
The discussion focuses on calculating the Lyapunov exponent of a damped, driven harmonic oscillator described by the equation ## \ddot{x} + 2\beta \dot{x} + \omega_0^2 x = f \cos(\omega t) ##. The general solution is expressed as ## A \cos(\omega t - \delta) + Ce^{r_1 t} + De^{r_2 t} ##, where ## r_1 = -\beta + \sqrt{\beta^2 - \omega_0^2} ## and ## r_2 = -\beta - \sqrt{\beta^2 - \omega_0^2} ##. The user seeks to express the term ## Ae^{x} + Be^{-x} ## in the form of ## e^{y}(A+B) ## and is advised to solve the differential equation explicitly. The conclusion asserts that when ## \beta^2 - \omega_0^2 << 1 ##, the Lyapunov exponent ## \lambda ## approximates to ## -\omega_0 ##.
  • Understanding of differential equations, specifically second-order linear differential equations.
  • Familiarity with Lyapunov exponents and their significance in dynamical systems.
  • Knowledge of complex numbers and their manipulation in mathematical expressions.
  • Basic principles of harmonic oscillators and damping effects.
  • Study the derivation of Lyapunov exponents in dynamical systems.
  • Learn about the stability analysis of damped harmonic oscillators.
  • Explore the implications of complex roots in differential equations.
  • Investigate the relationship between damping coefficients and system behavior in oscillatory systems.
Students and researchers in physics and engineering, particularly those focusing on dynamical systems, stability analysis, and oscillatory motion.
Ananthan9470
I am supposed to calculate Lyapunov exponent of a damped, driven harmonic oscillator given by ## \ddot{x} + 2\beta \dot{x} + \omega_0^2 x = fcos(\omega t)##
Lyapunov exponent is ## \lambda ## in the equation ## \delta x(t) = \delta x_0 e^{\lambda t} ##
The attempt at a solution
The gerenal solution of the system is given by ##Acos(\omega t - \delta) + Ce^{r_1 t} + De^{r_2 t}##
Consider two initial points 1 and 2. The solutions evolve to give ##Acos(\omega t - \delta) + C_1e^{r_1 t} + D_1e^{r_2 t}## and ##Acos(\omega t - \delta) + C_2e^{r_1 t} + D_2e^{r_2 t}## having initial points ##Acos(\delta) + C_{1,2} + D_{1,2}##.
Hence we have, ##\delta x(t) = C e^{r_1 t} + D e^{r_2 t}## and ##\delta x(0) = C + D ## where ##C = C_1 - C_2 ## and ##D = D_1 - D_2##
So now my problem now comes down to being able to write ##Ae^{x} + Be^{-x}## in the form of ##e^{y}(A+B) ## and figuring out y. And I don't know how I can do that. Am I doing this right? Or am I completely off track?
Ps. A and ##r_1## and ##r_2## have complex form depending on ## \beta## and ##\omega## etc.
##r_1## and ##r_2## in the equation can be changed into the form x and -x
Here's my suggestion and I'm no expert so you can take it or leave it. First, solve the differential equation explicitly. I found
r1= -β+√(β202)
r2= -β-√(β202)
δ=atan((ω202)/2ωβ).
You have δx(t) = e-βt((C1-C2)e+√(β202)t + (D1-D2)e-√(β202)t)
I assert that when β202 << 1, λ≅-ω0.
