How can the Maclaurin series for sin^2(x) be simplified?
John112
since the maclaurin series for sin x is alternating in sign (EQ1) so when you square it to get sin^{2}(x) (EQ2) the (-1)^{n} should become (-1)^{2n} (EQ3) which can be simplified down to (EQ4), but when i checked that series at wolframalpha the series was still alternating like: Why is that? So when we square it do we ignore squaring the (-1)^{n} and put that after we're done squaring the series?In the above post when I say EQ#, I'm referring to these equations
You seem to think that ##\left(\sum \alpha_n\right)^2 = \sum \alpha_n^2##. This is of course false. It's the same thing as saying that ##(x + y)^2 = x^2 + y^2##.
I can now see why sin^{2}(x) should be alternating, but how would I then simplify this algerbracially? how would I simplify ##\left(\sum \alpha_n\right)^2## ? Is using the half angle property for sin^{2}(x) my only method?
It's probably the easiest way to go.
The half-angle property is indeed the easiest way. But there also is a explicit way to multiply two series. This is called the Cauchy product: http://en.wikipedia.org/wiki/Cauchy_product So you can solve it with this too, but this is a lot more complicated.
Another way is to explicitely find the derivatives of ##\sin^2(x)## and see if you can find a pattern. But this is also not a very simple way to go.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
