Optimizing MadGraph for Exotic Physics Events
  • Thread starter Thread starter magistros
    Optimization
The discussion centers on a user experiencing long processing times when generating events in MadGraph, specifically with a complex input syntax involving exotic physics. The user reports that the process took over 500 minutes without results, while a simplified version completed quickly. A suggestion is made to switch from MadGraph 4 to MadGraph 5, which is noted for its improved speed and efficiency, especially for complex processes. It is emphasized that MadGraph 5 is backward compatible with models designed for MadGraph 4, allowing the user to transition without losing functionality. The user expresses reluctance to switch due to model compatibility but is encouraged to consider MadGraph 5 for better performance.
magistros
Dear forum,
I am new here, so hi to all!
I am using Madgraph to generate some events about exotic physics. The problem is that when I give this line
gg>(rho>(pip>j j)(pip>j j))(rho>(pip>j j)(pip>j j))
All these are declared in the particles.dat file.
The problem is that it takes too much time when I am trying the
./bin/newprocess
I left it working for 500 minutes and no results... It was saying:
Running...
So, I tried to make it smaller and it finished too fast! Do you have any idea, why it takes too much time? Is there any way making it use both cores?
Technology news on Phys.org
Dear magistros,
It seems from your syntax as if you are using MadGraph 4. Please switch to MadGraph 5, which can do this type of processes in quite reasonable time. Always try to use the most up-to-date software, it can make a world of difference (you find some speed benchmarks in the MadGraph 5 release paper http://arxiv.org/abs/arXiv:1106.0522).
Addendum: Please note that in order for us to directly receive your questions regarding MadGraph, please post your questions at https://answers.launchpad.net/madgraph5 instead of Physicsforums.
All the best,
Johan
Dear Johan,
thank you for your reply.. I can not use MadGraph5 because the model I want to run is programmed for MadGraph4...
But I will ask for MadGraph5.
Dear Magistros,
Of course MadGraph 5 is fully backward compatible in terms of models.
All the best,
Johan
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
