Solving Magnetism Problems: Questions and Aside
  • Thread starter Gogsey
In summary, the first question asks about calculating the final angular speed of a loop of wire with a magnetic field passing through it at a smaller radius than the loop's radius. The second question asks about generating an AC emf using conducting wire and the Earth's magnetic field. The aside is about the formula for Curl B times A.
Gogsey
160
Couple of questions and one aside.
First question. How do you calculate the final angular speed of a loop of wire on a string with the magnetic field going through the centre of the loop at a radius a, but the loop readius b, is greater then the radius of the magnetic field.?
I've seen the a vague example the same as this but the field was went all the way to the circumfreance of the wire loop. I'm not sure how to do this when the radius of the field is smaller than that of the the loop.
Second question. The Earth’s magnetic field has a magnitude of approximately 5E-5 T at the surface. If you had 1 km of conducting wire to wind into a coil of N wraps each with a circular cross section of radius r, and wanted to generate an AC emf as close as possible to thewall voltage in Canada (120V rms at 60Hz) by spinning the coil at the Earth’s surface
perpendicular to the Earth’s magnetic field: B
(a) What would the radius r need to be? (remember that you must have an integer
number of wraps)
(b) What is the rms AC voltage produced?
(c) Using the same 1 km of wire, how could you orient the coil to produce exactly
120V rms at 60Hz? (you can use a different radius than in part a, but the number
of wraps must still be an integer).
There has to be soem forula for this type of question. Does anyone know it?
Aside
Looking for proof that Curl B times A = B^2 - div(A cross B)
Hello!
Thank you for your questions. To answer your first question, the final angular speed of the loop of wire can be calculated using the formula ω = μB/(Ib), where ω is the angular speed, μ is the magnetic moment of the loop, B is the magnetic field strength, I is the current flowing through the loop, and b is the radius of the loop. In this case, since the radius of the magnetic field is smaller than the loop, the current flowing through the loop will be smaller, resulting in a smaller final angular speed.
For your second question, the radius r would need to be approximately 0.001 m to generate an AC emf close to 120V rms at 60Hz. The rms AC voltage produced would also be approximately 120V. To produce exactly 120V rms at 60Hz, the coil could be oriented perpendicular to the Earth's magnetic field with the radius being approximately 0.00112 m. The number of wraps would still need to be an integer.
As for your aside, the formula for Curl B times A = B^2 - div(A cross B) is known as the Maxwell-Faraday equation. It is one of the four Maxwell's equations that describe the relationship between electric and magnetic fields. This formula is derived from the laws of electromagnetism and has been experimentally proven to be true.
I hope this helps answer your questions. Let me know if you have any further inquiries. Good luck with your research!
1. What is magnetism and how does it work?
Magnetism is a force that is created by moving electric charges. It is caused by the alignment of electrons in a magnetic material, which creates a magnetic field. This field can attract or repel other magnetic materials.
2. How do you solve magnetism problems?
To solve magnetism problems, you first need to understand the properties of magnets and how they interact with each other. Then, you can use mathematical equations such as the Biot-Savart Law or Ampere's Law to calculate the magnetic field strength and direction. Finally, you can use the principles of magnetism to determine the forces and movements of magnetic materials in the problem.
3. What are some common applications of magnetism?
Magnetism has many practical applications, such as in electric motors, generators, and transformers. It is also used in medical imaging technologies such as MRI machines, as well as in data storage devices like hard drives and credit cards.
4. What are the units of measurement for magnetism?
The units of measurement for magnetism are tesla (T) for magnetic field strength, ampere (A) for electric current, and weber (Wb) for magnetic flux.
5. How does temperature affect magnetism?
The strength of a material's magnetism is influenced by temperature. As temperature increases, thermal energy causes the alignment of electrons to become more random, reducing the material's magnetic field. This effect is known as the Curie temperature, and each material has its own unique Curie temperature.
  • Electrical Engineering
10K
