Magnetic Field at a point between two capacitors
The discussion revolves around calculating the magnetic field between two parallel plate capacitors with given dimensions and a rate of potential increase. The user attempts to apply relevant equations, including the relationship between current, electric field change, and magnetic field. However, they encounter a discrepancy in their results, noting that their calculated magnetic field differs from the correct answer by a factor of 16. Clarification is sought regarding the interpretation of variables, specifically whether 'E' refers to electric field or voltage. The conversation highlights the importance of understanding the relationship between electric field and voltage in capacitor systems.
Renaldo
A parallel plate capacitor has circular plates of radius 12.0 cm that are separated by a distance of 4.0 mm. The potential across the capacitor is increased at a constant rate of 1300 V/s. Determine the magnitude of the magnetic field between the plates at a distance r = 3.0 cm from the center.
id = ε0A(dE/dt)
B = [μ0id/(2∏R2)]r
id = ε0A(dE/dt)
dE/dt = 1300 V/s
A = ∏R2
R = 0.12 m
ε0 = 8.85E-12
id = 5.2E-10
B = [μ0id/(2∏R2)]r
r = 0.03 m
R = 0.12 m
id = 5.2E-10
μ0 = 1.26E-6
B = 2.17E-16
Correct answer is 3.39E-15
How do I get there?
Renaldo said:
dE/dt = 1300 V/s
Note that on the left you have the rate of change of E, but on the right you have the value of the rate of change of V.
[I get an answer that differs from the stated correct answer by a factor of 16.]
I thought E stood for Vemf. Does it stands for Electric field?
E is electric field.
