Magnetic Field at the Center of a Coil
The magnetic field at the center of a circular coil with a radius of 0.22m carrying a 200 A current is calculated using the formula B = (4π × 10^-7)I / 2R, resulting in a field strength of 5.7 gauss. Additionally, a long straight wire carrying a 310 A current, located 0.05m from the coil, contributes to the total magnetic field. The magnetic field from the straight wire is calculated using B = (4π × 10^-7)I / (2πr). The total magnetic field at the center of the coil is the sum of the fields from both sources.
  • Understanding of magnetic fields and their calculations
  • Familiarity with the Biot-Savart Law
  • Knowledge of units of magnetic field (Tesla and gauss)
  • Basic algebra for solving equations
  • Research the Biot-Savart Law for calculating magnetic fields from current-carrying conductors
  • Learn about the principles of superposition in magnetic fields
  • Explore the effects of conductor shielding on magnetic fields
  • Study the conversion between Tesla and gauss for magnetic field measurements
Students studying electromagnetism, physics educators, and anyone interested in understanding magnetic fields generated by coils and straight conductors.
Dart82
The radius of a single coil of wire is 0.22m. It carries a 200 A current that flows clockwise.
A long, straight wire carrying a current of 310 A toward the right is located 0.05m from the edge of the coil. What is the value of the magnetic field at the center of the coil? Answer should be in gauss. (1Tesla = 10,000 gauss)
[URL=http://img472.imageshack.us/my.php?image=untitledar7.png][PLAIN]http://img472.imageshack.us/img472/4757/untitledar7.th.png[/URL][/PLAIN]
Magnetic field at the center of a flat circular coil: B = (4pi*10^-7)I / 2R
Magnetic field created by a long strait wire: B = (4pi*10^-7)I / 2*pi*r
The way i think about this problem is this: I know the wire will create its own magnetic field, this field will extend into the field created by the coil, thus increasing the total magnetic field. I solved for B created by the long straight wire, then solved for the B created by the flat circular coil. Next, i added the two magnetic fields together and converted T's to g's.
But doesn't conductors shield their interiors?
So, that means the outer straight wire has no effect @ the center of the coiled wire?
I'm not sure, but i know if i only calculate the field for the loop i get 5.7 gauss which is not the correct answer.
I think you are right, just add two of them because they are parallel.
