Can Magnetic Field Strength Decrease with Distance in Plasmas?
Magnetic field strength decreases with distance in free space according to the inverse square law, typically expressed as source field strength divided by 4πr². For a magnetic source of 1T, the field strength at 5cm would be calculated using this formula. In plasmas, the situation is more complex due to their conductive nature, which alters the interaction with magnetic fields. The magnetic field of a moving charge decreases as 1/r², while a dipole's field strength diminishes as 1/r³. Understanding these principles is essential for grasping how magnetic fields behave in dense plasmas.
7doughnuts
Hi
Can anyone tell me how magnetic field strength decreases with distance in free space? If the source was effectively a point souce in a plasma, what would the field strength be at a specific distance?
Is it source field strength/4 pi r sqrd?
As an example if the source was 1T, what would the measured field be at 5cm?
I've been reading some papers claiming massive field strengths inside dense plasmas and I'm curious as to how far these fields extend.
Thanks in advance :smile:
Well according to what I read somewhere
B=\mu H
Where H is field strength and B is flux density. But B would depend on what is being used to produce the magnetic field.
The magnetic field of a moving charge falls off like 1/r^2.
However, we usually see magnetic fields in the form of dipoles. A dipole has a north and a south pole--like a bar magnet. The field of a dipole falls off like 1/r^3.
That's in free space. Inside a plasma, it gets more complicated, because plasmas conduct electricity and interact with magnetic fields in complex ways.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
