I Magnetic field of Solar System planets
The discussion centers on the differences in magnetic fields among rocky planets, particularly focusing on why Earth maintains a strong magnetic field while others do not. Earth's active, molten core generates its magnetic field through the dynamo effect, supported by its size and the influence of its large Moon, which contributes to internal heat. In contrast, Venus, despite its similar size and potential for a molten core, lacks a significant magnetic field likely due to a thick lithosphere that inhibits convection necessary for a geodynamo. Additionally, the internal heat of Earth is primarily derived from residual thermal energy and radioactive decay, rather than tidal flexing. The conversation highlights the complexities of planetary magnetic fields and the factors influencing their strength and longevity.
Pedro de la Torre
Hello. I am reading a paper which says that only Earth (between the rocky planets) keep a strong magnetic field and it arose an question on this:
Why does the magnetic field of the planets decrease with time in such planets?
Why the magnetic field of the Earth is the only one which keeps strong?
Astronomy news on Phys.org
because their cores have cooled off
because it still has an actively rotating core
Likes rootone
Anticipating the obvious next question, why so for Earth and not the other rocky planets?
1, It is the largest of the rocky planets.
2, It has a very large Moon. which causes tidal friction; contributing to keeping the interior hot.
Likes Borg and davenn
The reason a hot core is important is because the Earth's magnetic field is believed to be generated by the dynamo effect. This requires a hot, molten mantle/core.
This is slightly misleading in two ways.
First, Venus is almost the same as the Earth (dimensions, composition, gross structure) and is thought to have a partially molten core close to the size of the Earth's, though there are some marginally plausible core compositions that could have solidified. However, if the core is molten, as seems likely, then Earth's "large" size cannot explain the absence of a field from Venus, while it does explain it for Mercury, Mars and the moon.
Assuming there is a molten core, it seems there is no significant convection - a necessary condition to initiate and maintain a geodynamo. In that case why no dynamo? It has been suggested that Venus's slow rotation inhibits convection, but this is generally discounted. (For example, here.) The more likely explanation is the thick lithosphere. This supresses plate tectonics and thereby restricts the loss of internal heat, a necessary condition for convection.
Secondly, the Earth's internal heat is primarily a consequence of residual thermal energy from accretion, radioactive decay and core formation. The contribution from tidal flexing is insignificant. (See, for example, Chapter 9, [page 1150] Basaltic Vulcanism on Terrestrial Planets.)
Likes anorlunda and davenn
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
