Magnetic field of the solenoid can be represented by the voltage
The magnetic field of a solenoid can be represented by the voltage induced in a search coil, following the principles of electromagnetism. The relevant formula for the magnetic field inside a current-carrying coil is B = (μ₀I)/(2πr), where μ₀ is the permeability of free space, I is the current, and r is the radius. Current can be derived from voltage using I = V/R, where R is the resistance in the circuit. Substituting this relationship into the magnetic field formula allows for calculating the magnetic field based on voltage. Understanding these equations is crucial for analyzing the magnetic properties of solenoids.
cutesoqq
According to which law the magnetic field of the solenoid can be represented by the voltage induced in the search coil ? :rolleyes: :biggrin:
Here's a formula that's use to find the field inside a current-carrying coil (should work for this too):
B=\frac{\mu_{0}I}{2\pi{r}}
And as you probably know:
I=\frac{V}{R}
Now just substitute (you do need to know the resistance inside the loop, though). I think this is what you are looking for.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
