Magnetic Field outside a solenoid
Determining the magnetic field outside a solenoid, particularly when using a ferrite rod, involves complex calculations influenced by the rod's properties, such as its permeability and magnetization. The magnetic field can be approximated using equations that consider the rod as a uniformly magnetized object, with specific formulas involving Gaussian units and Legendre polynomials for off-axis measurements. Accurate calculations depend on the hysteresis relaxation time being significantly smaller than the oscillation period, necessitating the use of magnetically soft ferrite. Users are seeking reliable equations and methods to calculate the magnetic field strength at various distances, as existing resources provide inconsistent information. Collaboration among physicists is encouraged to share findings and improve understanding of these calculations.
woje04
I am a physicist, a young physicist. I can't find information that agrees on how to determine the magnetic field at a distance from a solenoid.
We use a ferrite rod of 7.5" long wound with wire over 6.5" of it. The frequency it oscillates at is 73 kHz. If I know the current how can I determine the magnetic field at any point in space. I have looked everywhere and I get different information everywhere. I need some help.
I suspect that you need some info on the properties/material physics of ferrite and the magnetic fields that it produces first.
the ferrite we are using has a permeability of approximately 8000 and the fields we are measuring are very colse to uniform, (possible human error). What I need is an equation that will give me an accurate magnetic field strength at any point away from the solenoid.
You can treat the 7.5" ferrite rod as a uniformly magnetized magnet of magnetization
M=\mu nI/c, where n =turns/length, all in Gaussian units.
If the ends of the rod are circular, the B field outside will be the same as the E field due to two uniformly charged disks with surface charge \sigma =+ M and -M.
This field can be found using Legendre polynomials for off axis.
Reasonable approximations can be made if you are close to or far from the rod.
This all depends on the hysteresis relaxation time being small compared with the period of the oscillation. You need a magnetically very soft ferrite.
hey woje
did you ever find a way to calculate the field? I'm having the same problems you were with finding information on how to calculate the fields, so if you found anything I would really appreciate your help. Thanks.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
