Magnetic Induction Experiment Suggestion
4 replies · 3K views
sammy-e
Hello,
I am looking for ideas to demonstrate magnetic induction. There are a couple I've found, but I'm having trouble finding something with a little more excitement. The two I've seen are lighting a bulb with a changing magnetic field and launching an object by closing a switch connecting a charged capacitor and a coil. While I like the 2nd, I'd like to find something different because I've seen that one a few too many times. Variations are fine, though.
Any suggestions at all are welcome. Thanks in advance.
Wind about 15 feet of 30 AWG wire onto an iron or steel core (1/4 rod 2 inches long for instance). Connect the two ends ends of the wire that you have wound onto the core to a 1/8 inch phone plug. The type that would plug into a mic jack on a small cassette recorder. Then, plug it into the mic jack on the cassette recorder. Using earphones/headphones put the recorder in record mode and listen through the headphones. MOST recorders allow listening to what is being recorded through the headphone jack. You can sustitute a small audio amplifier for the cassette recorder, but most people already have access to a cassette recorder.
Now what to do with this. There are all kinds of interesting things to listen to with this device. Start with placing it close to a speaker with audio playing through it. You can attach it it various objects that may vibrate and hold a magnet close to it. Your imagination is the limit.
Sounds pretty cool and I like the simplicity, but I'm sort of looking for something with movement or a more visible effect. Definitely on the list, though...
The eddy currents in the iron will significantly attenuate the audible frequencies. I would use a ferrite rod if I knew where to get one.
It always worked for me. In fact, a single turn of one of the wires feeding a conventional telephone set wrapped around this gave nice audio.
