Magnitude and direction of force
A new user seeks assistance with a physics problem involving a horizontal bend in a pipeline that reduces in diameter and deflects water flow. The user is unsure how to approach the problem due to the gradual decrease in diameter from 600mm to 300mm and the angle of deflection. They have the necessary pressure information but need guidance on applying relevant equations. Respondents suggest posting in the appropriate forum section and recommend listing applicable equations and showing any attempts at solving the problem. This collaborative approach aims to help the user understand the problem-solving process better.
xxninixx
Hi everyone. I am new here so i don't know how this place works.
I got a problem::
A horizontal bend in a pipeline conveys water at a discharge at 1000l/s gradually reduces from 600mm to 300mm and deflects the flow through an angle of 60 degrees. At the larger end the pressure is 170000N/m^2. Determine the magnitude and direction of the force exerted on the bend.
I can do this question if it only had one length(600 or 300). Not sure what to do now because of the gradual decrease. help?
Science news on Phys.org
Welcome to Physics Forums.
For school homework problems, or any textbook-style problems that are for your own independent study, it works this way:
1. Post the problem in one of the Homework & Coursework Questions subject areas here:
2. When you make your post, list any and all equations that apply, or you believe could apply, to solving the problem. Solving this problem will involve using equations. If you don't know the equations, look for them in your textbook or class notes.
3. Try using those equations you found, see how far you can get towards solving the problem yourself. Show your attempt at solving the problem, however far you got, when you make your post.
Hope that helps.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
