What is the Magnitude of Acceleration in a Frictionless Equation?
To calculate the magnitude of the girl's acceleration while pulling the boy on a frictionless surface, the correct approach involves using Newton's second law, F=ma. The girl exerts a force of 4.50N on the boy, but the acceleration must be calculated using her mass, which is 30.3kg. The confusion arose from initially using the boy's mass instead of the girl's. After correcting this mistake, the proper calculation yields the girl's acceleration. Understanding the application of F=ma is crucial in solving such physics problems.
shimizua
A 30.3kg girl and a 56.0kg boy are on the surface of a frozen lake, 15.0m apart. Using a rope, the girl exerts a horizontal 4.50N force on the boy, pulling him toward her. Calculate the magnitude of the girl's acceleration.
so for this problem i am just confused about the equation to use. i know that it will use a frictionless equation but that is about all that i am sure of.
oh, and i had tried F=ma but that was wrong
OK. So, you tried F=ma. That is the equation you should use. I'll need to see your work to help you find your mistake.
i figured it out, i was using the guys m and that was the problem
OK cool! Good job.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
