Magnitude of normal force question
The discussion revolves around calculating the normal force acting on a suitcase being pulled at an angle. The normal force was determined to be 288N using the equation N - mg + vertical component = 0. To assess whether the suitcase will slide, the relationship between the applied force and the frictional force was analyzed, with kinetic friction being relevant once the suitcase is in motion. The frictional force calculated was 33.696N, which is less than the applied force of 105N, indicating the suitcase will indeed move. The conversation highlights the importance of understanding static versus kinetic friction in determining motion.
JadeLove
A woman pulls on her suitcase with a force of 105N at an angle of 38 degrees above the horizontal. The coefficients of static and kinetic friction between and suitcase and the floor are 0.273 and 0.117. The mass of the suitcase is 36 kg. what is the magnitude of the normal force acting on the suitcase due to the floor?
normal force - weight + vertical component =0
N - mg +105 sin 38=0
N=36kg*9.8m/s/s - 105 sin 38 = 288N
So I have figured out the magnitude of the normal force, but I don't know if the suitcase will slide. How do I figure that out?
Well for the suitcase to move, her horizontal force must be greater than the force of friction. How does friction relate to the normal force and which coefficient of friction would determine if it will move, static or kinetic?
Okay, but I'm given two different frictions, but I chose to work with kinetic because I know it's to do with motion... Or at least pretty sure.
Ff = u(288N)
Ff = 0.117 x 288N
Ff = 33.696
That's so little :S So since she's pushing with 105 N, the suitcase DOES move, correct??
Ff = u(288N)
Ff = 0.117 x 288N
Ff = 33.696
The kinetic friction is used when the body is already moving, in order for motion to occur you'd need to overcome static friction first. But once Fapplied<Ff, then no motion will occur.
Thank you makes sense, I got my answer my brother helped & showed me. Although I think you could have been a liiiiittle more like, well :D the formula for calculating Fs is etc, you know? Because you're too smart, & I don't really get it physics language, but now I get what you meant form the starts, thanks ^___^
Jade
Jade
But you knew what to do! You started correctly by calculating the normal force utilizing the vertical component. I tried to make it simple by how I wrote the second post. (you had all the formulas correct, so I assumed you knew had all the formulas correct)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
