Magnitude of Single Displacement:
The discussion revolves around calculating the magnitude of a single displacement for a golfer's strokes. The golfer's movements include three displacements: 7.4 m north, 2.8 m northeast, and 9.9 m at 79 degrees west of south. Participants clarify that the final answer is not the sum of the magnitudes of these vectors but rather the magnitude of a resultant vector derived from their x and y components. The correct approach involves calculating the x and y components for each vector, summing them, and then using the Pythagorean theorem to find the magnitude of the resultant vector. Ultimately, the calculated magnitude of the single displacement is approximately 10.769 m.
sonastylol
[SOLVED] Magnitude of Single Displacement:
Please bear with me, I'm going to try and properly format this, so you forum-goers actually want to help me out. :cool:
A novice golfer on the green takes three strokes to sink the ball. The successive displacements are 7.4 m to the north, 2.8 m northeast, and 9.9 m 79degreeswest of south. Starting at the same initial point, an expert (lucky) golfer could make the hole in a single displacement. What is the magnitude of this single displacement? Answer in units of m.
Magnitude = \sqrt{(axi)^2 + (ayj)^2}
For this equation:
Magnitude of A: \sqrt{(0)^2 + (7.4)^2}
Magnitude of B: \sqrt{(2.8cos45)^2 + (2.8sin45)^2}
Heres the tricky part:
Vector C is described as 9.9m 79 degrees west of south. Does this make it 191 degrees?
If yes: Vector C should be: \sqrt{(9.9cos191)^2 + (9.9sin191)^2}
I then add up the values of Magnitude A, B, C to get the answer... yes?
Thanks for your time.
No you don't add the magnitudes to get the final magnitude. You need to find out what direction he should have hit the ball to make it in one shot and then find the magnitude. Try drawing a diagram it will help.
i don't exactly understand what we are trying to do anymore then.. the answer isn't the addition of the 3 vectors magnitudes?
Is the answer the magnitude of one "new vector?" -- Like if we make a Vector D and give it an x and y component, from the addition of the first 3 vectors?
That is correct.
hmmm... I think maybe my angles are wrong.
I did Vector D x-components: 0 + (2.8cos(45)) + (9.9cos(191))
Vector D y-components: 7.4 + (2.8sin(45)) + (9.9sin(191))
The answer ended up being 10.769.Thank you :)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
