Maintaining PC Fans - All You Need to Know
  • Thread starter Thread starter pixel01
    pc
PC fans typically use sealed bearings and do not require oiling; if they are noisy, replacement is recommended. Oiling can lead to dust accumulation and potential damage, especially if the fan locks up due to worn bearings. While some argue that oiling can extend fan life and reduce noise, the consensus leans towards replacement as a more reliable solution. New case fans are inexpensive, making replacement a less stressful option. Ultimately, maintaining fan functionality is crucial to prevent overheating and damage to components.
pixel01
Hi all,
I just opened my desk PC case for cleaning. There are fans, one in the power supply and one over the CPU. Do I need to oil the fans and what kinds of oils are suitable for this purpose?
Thanks
The fans in your computer almost assuredly use sealed bearings and cannot be oiled. If a fan is making noise, it's because the bearings are shot, and the entire thing needs to be replaced. They're cheap.
- Warren
Don't oil them, chances are you'll spray oil everywhere, dust will stick to it, and you'll have no end of grief.
It's a good idea to replace the cpu fan before it is worn out. What could happen if the bearing is worn out, espessially if it it a low speed fan, is that the destroyed bearing will lock up the fan, so that the processor will be destroyed.
I don't see the problem with oiling the fans if you know what you are doing. Here is a good tutorial:
http://www.dansdata.com/fanmaint.htm
Oiling your old fans increases the chance they will last longer, and might actually improve efficiency/lower noise too.
Case fans are as cheap as $2-$3 now. It would be considerably less stressful just to buy a fan and put it in. Also you don't have to worry about spilling oil everywhere.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
