I have been contacted by members regarding my success in constructing one of these solar cells described earlier in the thread, so I thought I would post the results for those interested (either now or in the future).
I was able to successfully build several cells and get measurable electrical output from them using the conductive glass earlier described. In full, June, sunlight, I was able to measure a voltage of between .05 and .08 volts…not a lot, but it counts. I was never able to measure any current from the cell, probably since my cells were too small and the internal resistance on the glass was too great. When dying the TiO2, make sure to use real raspberries / raspberry juice / …, (I first tried using some [what I later found to be] artificial raspberry jelly which did not work). Although the instructs on constructing these cells says to wait to dye the TiO2 until after you have adhered it to the glass, I found it was easier to simply place some raspberry juice in with my TiO2 and water suspension, essentially pre-dying it, then painting it onto the glass with an ear swab and evening it out with a plastic straw and some scotch tape. Almost certainly, the TiO2 I was using was no where near nanoparticle size and this likely greatly affected my results.
Friday, we had a physics colloquium at my school on these very same photovoltaic cells. I had no idea this stuff was so cutting edge, even the one I built in my kitchen is essentially the same thing all these guys are doing research on (from what I heard, lots of interest in it in Japan [by Toyota]).
I really wish I would have brought something to write with to the presentation, but I did find out the answer to a few of the questions which were asked earlier. A lot of this is just going to chunks of info I am remembering, so excuse how terribly random all of it is put together.
It seems that these dye sensitized photovoltaic cells can theoretically get quite high efficiencies, somewhere around 90% I think (from what I could see on the graphs). Although they are experimenting with all different types of dyes and electrolytes, usually the highest efficiency is around the 500 nm wavelength of light, but all across the visible spectrum they can get fairly good results. What they are trying to do is get it so that they can absorb all the light from about 1.4 eV and down.
They are designing the cells / panels to last 20 years (100,000 “cycles”, I think) or so, so as to compete with the warranties of the regular silicon based solar cells.
Although the Iodide electrolyte is commonly used, they are trying to develop other, ionic liquid electrolytes as well as even solid / “gelled” electrolytes for use in the cell.
They are also coloring the cells a wide range of colors….one interesting picture was of a “plant” made with green colored solar cell “leaves” which absorbed the light shown on them and powered these butterfly things as a demo.
They can also made the cells very transparent (as well as colored)…almost like tinted / stained glass, you can still see through it to a good degree, but it also generates electrical energy. Also, making the cells flexible is a big deal too.
Another advantage of this dye synthesized cell compared to a silicon cell is that the electrons “live” longer after being released by the dye. If the electrons are not conducted away from the cell fast enough, they stand the chance of being reabsorbed and not doing any work. In a silicon cell, this happens very quickly, but in this cell, the re-absorption process takes longer so you can thicker coatings to use to absorb light.
I think he said that in China, they are able to produce these cells for about $1.00 per watt….but he also added that in China, their cost of labor is much less than in other places. The majority of the cost of the cell (over half) is in the conductive glass. They use a type of conductive glass with a resistance of about 1 ohm per square.
Here is the “poster” for the event,
http://www.utdallas.edu/physics/lectures/info/Fall2006/Graetzel/Graetzel%20poster%20150px.jpg
