Making sense of Differentiation in Thermodynamics
The discussion revolves around the differentiation of the adiabatic equation of state, pV^{\gamma}=constant, in thermodynamics. Participants explore the mathematical steps involved in differentiating this equation to relate changes in volume and pressure, addressing confusion regarding the presence of differentials in the process.
  • One participant questions the need for the differential dV in the differentiation of the equation, suggesting an alternative approach without it.
  • Another participant asserts that differentiating a function requires including differentials for all variables involved, emphasizing that d(x^n) always includes a differential.
  • Some participants discuss the product rule of differentiation and how it applies to the equation, with one providing a detailed derivation using logarithmic differentiation.
  • There is mention of confusion between the terms "differential" and "derivative," with participants clarifying their meanings and relationships.
  • A later reply indicates that the differentiation process is valid even if the infinitesimal factor is omitted, but this does not resolve the initial confusion about the signs in the equation.
  • One participant expresses that they have come to understand the topic better after the discussion, indicating a shift in their comprehension.
Participants express varying levels of understanding and confusion regarding the differentiation process. There is no consensus on the necessity of the dV term or the correct application of differentiation rules, indicating that multiple competing views remain.
Some participants note that the differentiation involves assumptions about the variables being functions of another variable, which is not explicitly stated in all posts. The discussion also highlights the importance of understanding the distinction between differentials and derivatives.
Calcifur
Hey there guys,
So I've been doing some Thermodynamics revision particularly involving the equation pV[itex]^{\gamma}[/itex]=constant , which is the adiabatic equation of state.
Now in my notes it says:
"we can differentiate this to obtain a relation between changes in volume and pressure:
V[itex]^{\gamma}[/itex]dp+[itex]\gamma[/itex]pV[itex]^{\gamma-1}[/itex]dV=0"
Now it might be because I'm still half asleep but I don't understand this action, particularly the need for the dV at the end.
Can someone tell me why it is not just:
udv+vdu
=pdV[itex]^{\gamma}[/itex]+V[itex]^{\gamma}[/itex]dp
=p[itex]{\gamma}[/itex]V[itex]^{\gamma-1}[/itex]+Vdp
Many thanks in advance
Science news on Phys.org
[tex]d(pV^x)=pd(V^x)+V^x dp=pxV^{x-1}dV+V^x dp[/tex]
but why does pd(V[itex]^{x}[/itex])=pxV[itex]^{x-1}[/itex]dV
The part I'm struggling to understand is the why there is a dV at the end.
Why is it not just pd(V[itex]^{x}[/itex])=pxV[itex]^{x-1}[/itex] ?
Thanks
dV^x=(dV^x/dV) dV=x V^(x-1) dV
Exactly, or in words, don't forget that you are calculating infinitesimal amounts. It's the same reason that d(p) is dp and not 1.
Calcifur said:
Hey there guys,
udv+vdu
That's just bad Calculus. For any variable x, [itex]d(x^n)= nx^{n-1}dx[/itex]. There is always a 'd something' in a differential. If you want to get rid of it, you have to specify which variable you are differentiating with respect to. If p and V are both functions of some other variable, say 't', then
[tex]\frac{d(pV^\gamma}{dt}= \frac{dp}{dt}V^\gamma+ \gamma pV^{\gamma- 1}\frac{dV}{dt}[/tex]
So when you differentiate V[itex]^{x}[/itex],
you must multiply the differential of V[itex]^{x}[/itex] with the differential of V alone?
Can anyone tell me what rule this is? I understand what happens, I'm just struggling to understand why.
Many thanks.
Can it be done like this?
The way I see it is you have to treat the differential of pV[itex]^{\gamma}[/itex] as two separate differentials and by that I mean:
[itex]\frac{d(pV ^{\gamma})}{dp}[/itex]=V[itex]^{\gamma}[/itex] and [itex]\frac{d(pV^{\gamma})}{dV}[/itex]=p([itex]{\gamma}[/itex]V[itex]^{\gamma-1}[/itex])
Which can be reformed so that:
[itex]d(pV^{\gamma})[/itex]=V[itex]^{\gamma}[/itex]dp and [itex]d(pV^{\gamma})[/itex]=p([itex]{\gamma}[/itex]V[itex]^{\gamma-1}[/itex])dV
Which can then be equalised:
V[itex]^{\gamma}[/itex]dp=p([itex]{\gamma}[/itex]V[itex]^{\gamma-1}[/itex])dV
And thus:
V[itex]^{\gamma}[/itex]dp - p([itex]{\gamma}[/itex]V[itex]^{\gamma-1}[/itex])dV=0
If this is correct then why is it minus when in the notes it says plus?
[itex]d (pV^\gamma)=\partial pV^\gamma/\partial p|_V\, dp+\partial pV^\gamma/\partial V|_p \, dV[/itex]
Now you are considering an adiabatic process in the course of which the product pV^gamma does not change, hence [itex]d(pV^\gamma)=0[/itex].
No, this comes from the product rule of differentiation. Consider that you have a function:
[tex]f(x)=u(x)v(x)[/tex]
then, take its logarithm and differentiate:
[tex]ln[f(x)]=ln[u(x)v(x)]=ln[u(x)]+ln[v(x)][/tex]
[tex]\frac{d}{dx}(ln[f(x)])=\frac{d}{dx}(ln[u(x)]+ln[v(x)])=\frac{d}{dx}(ln[u(x)])+\frac{d}{dx}(ln[v(x)])[/tex]
then do the calculations:
[tex]\frac{1}{f}\frac{df}{dx}=\frac{1}{u}\frac{du}{dx}+\frac{1}{v}\frac{dv}{dx}[/tex]
but, since f=u v, we can multiply on both sides by uv:
[tex]\frac{u v}{f}\frac{df}{dx}=\frac{u v}{u}\frac{du}{dx}+\frac{u v}{v}\frac{dv}{dx}[/tex]
and we get:
[tex]\frac{df}{dx}=v\frac{du}{dx}+u\frac{dv}{dx}[/tex]
If you replace in your problem [itex]f(x)=pV^x[/itex] and [itex]u(x)=p(x),v(x)=V^x[/itex] you have the proof.
Edit: The "no" was for Calcifur's post :)
There's also a confusion in semantics here: "differential" does not mean the same as "derivative"; the former is an infinitesimal quantity, the latter is not; both are related by an infinitesimal factor [itex]\mathrm d x[/itex]
Indeed. Note however that even if you omit the dx from the proof above, it's still valid for differentials (which is the case we are discussing here, thanks mr. vodka!)
Ok, I think I finally understand it now! :approve: Thanks to everyone who gave their input! I think I was overcomplicating it!
  • · Replies 22 ·
  • · Replies 31 ·
