Making sense of Differentiation in Thermodynamics
The discussion centers on the differentiation of the adiabatic equation of state, represented as pVγ = constant. Participants clarify the need for the differential terms in the equation Vγdp + γpVγ-1dV = 0, emphasizing that each variable must be treated as a function of another variable. The differentiation process is explained using the product rule, highlighting the importance of including differentials to accurately represent changes in volume and pressure. The conversation concludes with a consensus on the necessity of these terms for proper calculus application.
  • Understanding of the adiabatic process in thermodynamics
  • Familiarity with calculus, specifically differentiation and the product rule
  • Knowledge of differential forms and their applications
  • Basic grasp of thermodynamic variables such as pressure (p) and volume (V)
  • Study the application of the product rule in calculus
  • Learn about differential forms and their significance in thermodynamics
  • Explore the implications of the adiabatic process on thermodynamic systems
  • Review advanced calculus topics, including partial derivatives and their applications
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and calculus, will benefit from this discussion. It is also valuable for anyone seeking to deepen their understanding of the mathematical foundations underlying thermodynamic principles.
Calcifur
Hey there guys,
So I've been doing some Thermodynamics revision particularly involving the equation pV^{\gamma}=constant , which is the adiabatic equation of state.
Now in my notes it says:
"we can differentiate this to obtain a relation between changes in volume and pressure:
V^{\gamma}dp+\gammapV^{\gamma-1}dV=0"
Now it might be because I'm still half asleep but I don't understand this action, particularly the need for the dV at the end.
Can someone tell me why it is not just:
udv+vdu
=pdV^{\gamma}+V^{\gamma}dp
=p{\gamma}V^{\gamma-1}+Vdp
Many thanks in advance
Science news on Phys.org
d(pV^x)=pd(V^x)+V^x dp=pxV^{x-1}dV+V^x dp
but why does pd(V^{x})=pxV^{x-1}dV
The part I'm struggling to understand is the why there is a dV at the end.
Why is it not just pd(V^{x})=pxV^{x-1} ?
Thanks
dV^x=(dV^x/dV) dV=x V^(x-1) dV
Exactly, or in words, don't forget that you are calculating infinitesimal amounts. It's the same reason that d(p) is dp and not 1.
Calcifur said:
Hey there guys,
udv+vdu
That's just bad Calculus. For any variable x, d(x^n)= nx^{n-1}dx. There is always a 'd something' in a differential. If you want to get rid of it, you have to specify which variable you are differentiating with respect to. If p and V are both functions of some other variable, say 't', then
\frac{d(pV^\gamma}{dt}= \frac{dp}{dt}V^\gamma+ \gamma pV^{\gamma- 1}\frac{dV}{dt}
So when you differentiate V^{x},
you must multiply the differential of V^{x} with the differential of V alone?
Can anyone tell me what rule this is? I understand what happens, I'm just struggling to understand why.
Many thanks.
Can it be done like this?
The way I see it is you have to treat the differential of pV^{\gamma} as two separate differentials and by that I mean:
\frac{d(pV ^{\gamma})}{dp}=V^{\gamma} and \frac{d(pV^{\gamma})}{dV}=p({\gamma}V^{\gamma-1})
Which can be reformed so that:
d(pV^{\gamma})=V^{\gamma}dp and d(pV^{\gamma})=p({\gamma}V^{\gamma-1})dV
Which can then be equalised:
V^{\gamma}dp=p({\gamma}V^{\gamma-1})dV
And thus:
V^{\gamma}dp - p({\gamma}V^{\gamma-1})dV=0
If this is correct then why is it minus when in the notes it says plus?
d (pV^\gamma)=\partial pV^\gamma/\partial p|_V\, dp+\partial pV^\gamma/\partial V|_p \, dV
Now you are considering an adiabatic process in the course of which the product pV^gamma does not change, hence d(pV^\gamma)=0.
No, this comes from the product rule of differentiation. Consider that you have a function:
f(x)=u(x)v(x)
then, take its logarithm and differentiate:
ln[f(x)]=ln[u(x)v(x)]=ln[u(x)]+ln[v(x)]
\frac{d}{dx}(ln[f(x)])=\frac{d}{dx}(ln[u(x)]+ln[v(x)])=\frac{d}{dx}(ln[u(x)])+\frac{d}{dx}(ln[v(x)])
then do the calculations:
\frac{1}{f}\frac{df}{dx}=\frac{1}{u}\frac{du}{dx}+\frac{1}{v}\frac{dv}{dx}
but, since f=u v, we can multiply on both sides by uv:
\frac{u v}{f}\frac{df}{dx}=\frac{u v}{u}\frac{du}{dx}+\frac{u v}{v}\frac{dv}{dx}
and we get:
\frac{df}{dx}=v\frac{du}{dx}+u\frac{dv}{dx}
If you replace in your problem f(x)=pV^x and u(x)=p(x),v(x)=V^x you have the proof.
Edit: The "no" was for Calcifur's post :)
There's also a confusion in semantics here: "differential" does not mean the same as "derivative"; the former is an infinitesimal quantity, the latter is not; both are related by an infinitesimal factor \mathrm d x
Indeed. Note however that even if you omit the dx from the proof above, it's still valid for differentials (which is the case we are discussing here, thanks mr. vodka!)
Ok, I think I finally understand it now! :approve: Thanks to everyone who gave their input! I think I was overcomplicating it!
  • · Replies 22 ·
  • · Replies 31 ·
