Can Free Particle Scattering Be Simplified Using Sine and Cosine Functions?
  • Thread starter Thread starter splitringtail
splitringtail
[SOLVED] Making the math easier
I am doing a free particle scattering/tunneling by a well and a barrier combination. There are four regions of interest where the wave numbers are different. I have seen the solution inside the well be expressed as a linear combination of exponents or sine and cosine functions.
Now I have only seen free particles in these problems as a linear combination of exponents... can I rewrite them as a linear combination of sine and cosine. I am finding these exponent forms very very cumbersome b/c I get two terms when I match the wave functions @ x=0, if they were in a sine and cosine combination, then it would sine would be zero @ x=0
This is more of a discussion and there is too much work to present here.
You can use the identity
e^{i\theta} = \cos\theta + i \sin\theta[/itex].<br /> So, for example<br /> \sum_k a_k e^{ikx} = \sum_k a_k (\cos(kx) + i \sin(kx))<br /> and then you can try to rewrite this (for example, if the sum runs from -infinity to +infinity, you can use that sin(-kx) = -sin(kx) and cos(-kx) = cos(kx) to simplify).<br /> If the exponent is real, you can use<br /> e^{\theta} = e^{i(-i\theta)} = \cos(-i\theta) + i sin(-i\theta)<br /> and subsequently <br /> \sinh x = -i \sin(i\theta), \cosh x = \cos(i\theta)<br /> to write them in hyperbolic sines and cosines. <br /> <br /> Conversely, if you have a combination of sines and cosines, you can always write them in exponentials. All of this is the reason we usually write a plane wave as something like exp(i(kx - wt)) with k the wavevector and w the frequency: you can write it out in sines and cosines to say that it really &quot;waves&quot; <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
