Making this derivative look prettier
  • Thread starter Thread starter Flappy
    Derivative
Flappy
Find the 1st and 2nd derivative:
f(x) = x^{1/3}* e^{-x^2}
f'(x) = x^{1/3} * -2xe^{-x^2} + e^{-x^2} * \frac {1}{3}x^{-2/3}
I simplified this to:
[e^{-x^2}]*[-2x^{4/3} + \frac {1}{3}x^{-2/3}]
Also to find the x values is
x^{-2/3}*[-2x^{2} + \frac {1}{3}]
x^{2} = 1/6
x = +- \sqrt{1/6}
Okay now I'm trying to make the 2nd derivative be simplified so I can solve for the inflection points.
f''(x) = [e^{-x^{2}}]*[\frac {-8}{3}x^{1/3} - \frac {2}{9}x^{-5/3}] + [-2x^{4/3} + \frac {1}{3}x^{-2/3}]*[-2xe^{-x^{2}}]
Im kind of stuck after this. I think it would involve taking out an e^{-x{2}} but it's very confusing.
… just keep going …
Hi Flappy! :smile:
Just keep going … you should get }x^{-5/3} e^{-x^2} times a quadratic in x^2. :smile:
Hmm I tried to do this:
e^{-x^{2}}[ -\frac {8}{3}x^{1/3} - \frac {2}{9}x^{-5/3} + 4x^{7/3} - \frac {2}{3}x^{1/3}]
I multiplied the -2x and then took out the e^(-x^2). Would this be right? I'm not sure where you're getting x^(-5/3)
Ah, i think i see it. There's a common factor of x^(-5/3)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
