Wood/Glass/Metal Where to Find Uranium Glass Beads/Wands & Safety Protocols
Uranium glass beads and wands can be created using uranyl nitrate (UO2(NO3)2), but sourcing this material can be challenging. Safety protocols are essential when working with uranium compounds, including controlling dust and ensuring proper respiratory protection. The safety measures may vary when handling raw glass due to potential off-gassing and glass dust. For small decorative beads, a higher uranium content may be necessary compared to thicker glassware. Purchasing existing uranium glassware, such as from eBay, and melting it down for casting is a viable option. In Australia, acquiring uranium oxide (yellow cake) requires registration as part of the decorative glass industry. Depleted uranium may also be accessible in regions with an atomic energy sector. The specific safety requirements and legalities depend on the intended use and processes involved.
pimpypot
TL;DR Summary
source and safety of uranyl nitrate, UO2(NO3)2 for green UV art glass
I cannot find a source of uranium glass beads/wands for art making. It is mentioned online that one can make UV glass with a derivative of uranyl nitrate, UO2(NO3)2 . Does anyone know a source of uranyl nitrate, or raw glass material, and what are the minimum safety protocols, such as quantity, dust control, and respiration mask. Do the safety protocols change when working with raw glass, such as with off gassing or glass dust? It is my understanding either scenario is safe and legal as long as the working quantity and particulates are kept to a minimum.
First eBay search international for “URANIUM Czech Vaseline glass”
https://en.wikipedia.org/wiki/Uranium_glass
Do you want to make a significant amount of glassware or do you want a few uranium glass beads for decoration?
Small beads will probably need a higher U% than thicker glassware, but you might buy the glassware new and cheap on eBay, then melt it down to cast your own beads.
You can probably buy yellow cake = uranium oxide in Australia. You will probably need to register with your state as a member of the decorative glass industry before you can get a license to buy. https://en.wikipedia.org/wiki/Yellowcake
Depleted Uranium, DU, is used as ballast weights and may be available in the US or Europe where there is an atomic energy industry. That may be the source of the uranium in the Czech beads.
Safety issues will depend on the processes you will carry out.
You have not clearly specified the required end result.
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
