Man Rows Boat: Force, Angle, Velocity Examined
  • Thread starter Const@ntine
  • Tags
    boat
In summary, the man pushes a weightless stick, which creates a force of 240 N to the bottom of the lake. The boat is slowed down by the water and the stick creates an angle of 35 degrees with the vertical. The net force is 47.5 N which faces forward.
Const@ntine
285
The man pushes the weightless stick, and so exerts a force with a magnitude of 240 N to the bottom of the lake. Hypothesize that the stick is in the same vertical as the boat's keel. At some point in time, the stick creates a 35 degree angle with the vertical and the water exerts an horizontal force of 47.5 N to the boat, with a direction opossite to the velocity's, which faces towards the front of boat, and has a magnitude of 0.857 m/s. The mass of the boat, the cargo and the man is 370 kg.
a) The water exerts an upthurst force, which faces vertically upwards. Find the magnitude.
b) Consider that these forces stay constant for very short time spans. With that info, find the velocity of the boat 0.450 s later.
ΣF = m*a
Vf = Vi + a*t
The thing is, I'm not sure how the stick, the boat and the bottom of the lake connect. When he moves the stick, he exerts a force directly at the bottom, correct? So, since he's moving forwards (let's say forwards is east), he exerts a 240 N force at the bottom, which faces to the east. Then, since the stick is weightless, according to Newton's 3rd Law, where does the bottom exert the opposite force to?
When the stick is at an angle, then this new force crates a net force, with both horizontal and vertical vectors. At first, I figured I'd find the vertical force, I'd subtract it from the weight, and I'd be done, but that's not the correct result. I'm obviously missing something (I figure the whole "370 kg is the mass of the boat, the man and the cargo" play some role later?), so I'd appreciate the help.
Then the thing to do is: make a drawing.
The stick can be weightless and exert a force nevertheless; in this case along its length. Man pushes down and backward, stick pushes up and forward. Up you need for a), forward for b).
So, the 240 N force goes upwards then? I made a drawing, but I'm not sure how the bottom, the stick and the boat are connected. For example, I know that the center of the Earth exerts a force on the boat which is what we call the weight, and that's downwards. Then, because the boat is on top of the water, the water/bottom causes an upper thurst to the boat, that faces upwards, and it's what I'm trying to find. But when the stick creates a 35 degree angle with the vertical, and thus the bottom exerts a 47.5 N force to the boat (that faces west while it moves east), then where is the stick facing? How do the bottom, the stick and the boat connect?
No, it's at an angle of 35 degrees with the vertical. Part of it is upward, part is forward. Upward you need for a), forward you need for b) (Didn't I already write that ? :smile:)
Darthkostis said:
I made a drawing
Would you like some constructive comments ? Then post it.
No 'thus' . The forward part of the 240 N is not 47.5 N. The 47.5 N is the (viscosity) friction force the water exerts against the moving boat, doing its best to slow it down, while the man does his best to push it forward.
If you find the water complicating, imagine a skateboard, or a cart: :rolleyes:
No and yes: it's not the center but the entire earth. Magnitude ##mg##.
The stick is facing forward at an angle of 35 degrees with the vertical.
The point in time where the stick exerts a force of 240 N to the bottom (when it's completely vertical, it doesn't create an angle) is different than the point in time when it creates an angle with the vertical. My problem isn't picturing the net force, it's how the stick affects the bottom. Should I just imagine it that it touches the bottom, and so because the stick is weightless, the 3rd LoN is between the bottom of the sea and the boat as a whole?
You are expected to assume that the stick is under compression only. It conveys no twisting or other force perpendicular to its axis. You are expected to assume that the magnitude of this force is 240 N regardless of how the stick is angled.
Edit: Even if those assumptions are not the expected ones, the rule of thumb is to clearly state your clarifying assumptions about the problem up front and then solve. Doing so will assure at least partial credit.
It's not completely vertical: It is only vertical in the plane of the keel (the 'left-right vertical' ) : it makes an angle of 35 degrees with the 'forward-backward vertical'.
We haven't reached the sea yet. And yes, the boat as a whole will do: actually it's via the man who distributes his ##mg## over the vertical component of the 240 N he exerts on the stick (and therefore the stick on him) and the boat. On with part a) which is now almost solved !
Man on boat rows
Is actually not such a good title. Punting is the word.
Students do it at Oxford and Cambridge. The english learned it from the dutch in the sixteenth or seventeenth century. 'Punteren' was the means of local transportation in Giethoorn well into the twentieth century.
Yeah, I get it now. I forgot all about friction force, and assumed that the stick is at some point completely vertical, and "pushes" the bottom (like when you try to stick a flag in the ground). So technically, the stick is in the same vertical space, but can still move left and right. The 240 N that it exerts is in a net force, with both an x and y vector. The 47.5 N is just a horizontal force that plays a role in (b).
So, by that logic, vertically, on the boat I have the following forces:
|Fg| = 370 kg * 9.8 m/s^2 = 3626 N (which faces downwards)
|Fsy| = 240 N * cos(35) = 196,6 N (which faces upwards) - The y vector of reaction of the bottom to the force the stick exerts to it
And so: ΣFy = 0 < = > Fwy + 196,6 N = 3626 N <=> Fwy = 3429,4 N ~ 3,43 kN (the book's answer)
Thanks for all the tips! I got caught up with the stick and misssed that the 47.5 N and the 240 N were totally different forces and not just the same one at different points in time.
You're in business! On to part b) and no need to think overly complicated.(A vertical 'space'? o0) -- at each pointthere are two vertical planes perpendicular to each other. The boat moves in an east-west plane which is where the stick is. The stick is NOT in a north-south vertical plane)
Well, I'm still having a bit of trouble with the english definitions, as it's not my native language, and the book I'm using has been translated. I'm mostly going by what I know and online dictionaries. Thanks for the tips though, they're very useful, since at some point I'll have to be able to fluently explain and/or translate problems/thoughts in english, complete with definitions (I don't have a problem with the speaking part, but such advanced and specialized words are a tad new to me).
Same here. It's a difficult, contorted, ambiguous, class-oriented disaster of a language for science, but I suppose it beats chinese. And it has beaten esperanto ([edit] and latin).
My native is greek so there is some overlap, but yeah, it is hard to get the hang of it when it comes scientific terms and concepts. Well, try it 'till you make it as they say.
As far as I can tell, you're doing extremely well: not everyone uses terms like 'a tad new' :smile:
It's mostly because of my teacher. He was from South Africa and lived in England for a long while, so I got to know the various phrases and British pronunciation early on. It's the various terms that I'm having teeny bit of trouble with, but I'll get the hang of it eventually...I hope...
1. What is the force that propels a man rowing a boat?
The force that propels a man rowing a boat is generated by the muscles in the arms, back, and core of the rower. This force is applied to the oars, which push against the water, propelling the boat forward.
2. How does the angle of the oars affect the force of rowing?
The angle of the oars can greatly affect the force of rowing. A larger angle of the oars, with the blades further apart, will result in a stronger push against the water and a greater force propelling the boat. However, a smaller angle will result in less force, but a more efficient stroke.
3. What role does velocity play in rowing?
Velocity, or the speed at which the boat is traveling, is an important factor in rowing. It is directly related to the force and angle of the oars. The faster the rower can move the oars through the water, the greater the force applied and the faster the boat will travel.
4. How does rowing technique impact the force, angle, and velocity?
Proper rowing technique is crucial in optimizing the force, angle, and velocity in rowing. A rower must have a strong and efficient stroke, using their entire body to generate force and maintain a consistent angle of the oars. This will result in a faster velocity and a more effective rowing experience.
5. What other factors can affect the force, angle, and velocity in rowing?
There are several other factors that can affect the force, angle, and velocity in rowing. These include the weight and size of the boat, the water conditions, and the skill level of the rower. External factors such as wind and current can also impact these variables in rowing.
14K
