Many students pursue Mechanical and Electrical Engineering rather than
Many students choose Mechanical and Electrical Engineering (ME and EE) over Aerospace Engineering (AE) due to the broader applicability of ME and EE in various industries. The discussion highlights that while AE courses are specialized, the skills learned can be transferable to other fields. However, ME and EE programs are perceived to offer more versatile coursework, making graduates more appealing to employers. It is noted that AE graduates may need to demonstrate their versatility more actively in the job market, particularly when facing automated resume screenings. Ultimately, practical skills and mindset are emphasized as crucial for success in engineering careers, regardless of the specific degree.
redgoat
Many students pursue Mechanical and Electrical Engineering rather than Aerospace Engineering. Only a few student takes Aerospace Enginerring. Do you know why?
Mechanical and electrical engineering have much wider domains of applicability in industry.
- Warren
I would actually like to know whether or not that is the real reason. What are the upper level course's Mechs take? I've heard thousands of times that ME and EE have wider applicability but I don't know wheter or not that's true. For comparison, here are the courses I take as AE starting with year 2 because that's when we start taking engineering classes.
Engineering Sciences: Statics,Solid Mechanics,Dynamics,Fluid Mechanics, Thermodynamics, Electrical Engineering I and II. Those are the general engineering classes that everyone has to take and understand.
Now specifically AE classes are Aerodynamics I and II, Aircraft Structures I and II and then depending on the area of focus you have the choices of classes like Stability and Control, Control Systems Analysis, Space Mechanics, Turbine and Rocket Engine Structures and Instrumentation, and of course design classes.
Now those classes sound pretty specific but you can take many of the concepts in them and apply them to other fields. I would personally like to know what the detailed type classes ME and EE take to see if they are really more versatile like everyone says. If you look at most of the upper level classes they contain more complex aspects of thermodynamics, fluid mechanics and dynamics, solid mechanics, and general dynamics, and even electrical systems. I would assume that ME would take classes that are similar in nature. Plus EE would be focused more on electrical systems and not focus and the other aspects I mentioned above.
What you said is true mostly. My 3rd and 4th years were more general design related. Half were more advanced versions of classes already taken. I think that (around me anyways) if you had an AE degree, you wouldn't be hurting yourself. However you would have to work a bit harder to prove that you had the versatility of an ME. I think the most important part is to have the mindset and practical skills of engineering, not so much your course background. You'll have so much learning to do in your profession that the college courses you took will take a back seat to how you actually conduct yourself on the job.
The hardest part for an AE would be getting by the resume scanners that do the quick, 2 second scan to get the major points. If they're looking for an ME and they see AE, you may need a little something-something to get you by that first hump.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
