Mapping Points on the Bloch Sphere
The discussion revolves around the mapping of discrete points on the surface of the Bloch sphere, specifically focusing on limiting the ranges of the spherical coordinates theta and phi. Participants explore techniques for achieving this mapping and the implications for qubit state probabilities.
  • One participant seeks to limit the range of theta from 0 to pi to a smaller range defined by theta_1 and theta_2, questioning whether this will result in actual mapping to new points or merely alter the probabilities of qubit states.
  • Another participant asks for clarification on the mapping process and the nature of the problem being addressed.
  • A participant clarifies that they intend to map points from spherical coordinates (theta_1, phi_1) to (theta_2, phi_2) while limiting the ranges of theta and phi.
  • There is a mention of using orthonormal functions to limit the ranges, with a question about whether this will lead to a specific point on the sphere upon observation or just affect the probabilities.
  • One participant introduces the density matrix representation of a qubit state, suggesting that the trace of a specific operator can relate to the angle theta.
  • Another participant suggests that selecting a region on the Bloch sphere can be achieved by restricting the expectation values of certain operators.
Participants express varying levels of understanding and approaches to the problem, with no clear consensus on the best method for achieving the desired mapping or the implications of the proposed techniques.
Some assumptions about the mathematical framework and the implications of the mapping process remain unaddressed, and the discussion does not resolve the complexities involved in the proposed techniques.
captainhampto
Hey guys,
I'm attempting to map some discrete points on the surface of the Bloch sphere:
For instance, the full spectrum of ranges for variable theta is 0 < theta < pi. However, my goal is to limit that range from some theta_1 < theta < theta_2. I was going to use a spherical harmonic technique to limit the ranges, but my question is this:
If I do succeed in limiting the ranges, will this actually map to these new points (theta_1 and theta_2) or will it simply alter the probability of the qubit represented by the Bloch sphere to collapsing to either basis state of 0 or 1?
My main goal is to have some value between theta_1 and theta_2 arise from this technique so that I do not get the full spectrum of 0 to pi. If a better technique exists I would be most obliged to learn of it.
If any further clarification is needed, please do not hesitate to post a response, as perhaps I am leaving out some detail that is crucial. Either way, thanks and looking forward to some responses.
To map from where to where? And why is mapping a point from one set to another set a problem?
To map from some point on the sphere denoted by spherical coordinations (theta_1, phi_1) to (theta_2, ph_2).
where instead of the full range:
0 <= theta <= 180
0 <= phi <= 360
the ranges are limited by some theta_1, theta_2, phi_1, and phi_2:
theta_1 <= theta <= theta_2
phi_1 <= phi <= phi_2
I have a pretty good idea of how to limit the ranges, basically by creating a set of new functions which are orthonormal over the set of new value ranges.
I suppose my main question is that, using these new functions on the sphere, when the qubit is observed will it collapse to some point on the sphere? Or will it simply alter the probability of the qubit collapsing to either state.
Or, perhaps if I am making this too complex. Basically, if there is a cleaner method for obtaining some value between the ranges of
when the qubit collapses, that is what I am after.
Thanks again, and I hope this clears up some of my intent. If not, I really do not mind trying to clear up more if you or anyone else is still not following my reasoning. (I apologize if so)
I don't know if this will help or not, but every pure state of a qubit is described by the density matrix
[tex]\rho(\mathbf{n})=\frac{1}{2}(I+\mathbb{\sigma}\cdot\mathbf{n})[/tex]
where [itex]\mathbf{n}[/itex] is the unit vector.
It follows that
[tex]\mbox{Tr }(\sigma_3\rho(\mathbf{n}))=\cos(\theta)[/tex]
So, one can select a region on the Bloch sphere simply by restricting the ranges of expectation values of, say, [itex]\sigma_3[/itex] and [itex]\sigma_1[/itex].
Thanks a lot for the help arkajad. I will certainly give your approach a shot. Thanks again.
  • · Replies 20 ·
  • · Replies 20 ·
