Finite Modules and Surjective Endomorphisms: An Elementary Exploration
  • Thread starter Thread starter mathwonk
    Finite Modules
mathwonk
2024 Award
In the spirit of challenges, here is a surprizingly simple question about finite modules, that I did not know the answer to until recently. It is so elementary that I suspect it was common knowledge to the ancients and only forgotten as algebra became more sophisticated.
We all know that finitely generated modules mimic many properties of finite sets. E.g. a self map of a finite set is bijective if and only if surjective, if and only if injective.
Similarly, an endomorphism of a finite vector space is an isomorphism if and only if injective if and only if surjective.
But what if the ring is not a field, but just a commutative ring with identity? Then e.g. multiplication by 3 is an injective endomorphism of Z, a finite Z-module, but it is neither surjective nor injective?
can you find an example in the other direction? i.e. can you find a surjective endomorphism of a finite R module which is not injective?
I claim not. There is an abstract proof for modules which are "noetherian" i.e. not only finitely generated, but in which also every submodule is finitely generated.
Namely such modules cannot have a strictly increasing infinite sequence of submodules. But the sequence of kernels of iterates of a surjective endomorphism cannot terminate unless they are all zero.
But there is a simpler more elementary proof for al finite modules, without assuming noetherian. can you find it?:smile:
notice this implies that if two finite R modules are isomorphic, then every surjective homomorphism between them is an isomorphism! Isn't that amazing?
Hence if you mod out any finite R module by a non trivial submodule, what you get is never isomorphic to the original module. or if you have two properly nested submodules of a finite free module, the two quotients are never isomorphic.
in particular a non trivial quotient of a free module is never free on the same number of generators. thus the rank is well defined.
again, in any free rank n module, n generators are always independent, but n independent elements may not generate.
I wouldn't say Z is a finite Z module, merely a finitely generated Z module. I think the distinction is important and one you have glossed over by using both terms interchangably.
i thought those were synonyms. i mean finitely generated if they are not.
i thought the only time one distinguished thoise terms was when one is discussing algebras, where finitely generated is weaker than finite, i.e. then finitely generated means as an algebra and finite emans as a module.
but for modules i know of no other concept called finite except finitely generated. what am i forgetting?
in particular why is Z not a finite Z module?
oHH! of course!~ the super naive, obvious meaning of finite, is duhhh... a finite set which is a module!
of course i do not mean that. so let's say finitely generated.
Oddly, the terminology of "finite A- modules" has been standard for over 40 years, as in Lang algebra, e.g., and even in Atiyah - MacDonald in the case of "finite A algebras". but I see how it could easily confuse someone.
More recently Eisenbud avoids it for modules but also uses it for algebras as do A-M, where of course it is just as double edged.
amazing as it seems, i have never before noticed that this terminology might be confusing, and no one has ever objected to it before.
perhaps as an algebraic geometer i am too used to special meanings of finite, like morphisms induced by ring maps which are integral extensions, i.e. module finite ring maps.:-p
try case one, if R is a commutative ring with 1, and I a non zero ideal, then R/I is never isomorphic to R as R module.
then try to go to R+R.
Matt, I think I should stick to my original terminology. Then I could pose problems for my class like: "find an example of a finite module which is not finite."
and then also "prove every finite module is finite." Funny I never thought of that. Maybe that's why some people find my lectures confusing.
