Mars as a pre-tectonic model for Earth?
Mars may not serve as a pre-tectonic model for Earth due to its distinct geological features. The planet exhibits a dichotomy between its southern and northern hemispheres, characterized by a thick, heavily cratered crust in the south and a younger, thinner crust in the north. Evidence of strong residual magnetism and early spreading ridges suggests past tectonic activity, while features like the Tharsis bulge and Olympus Mons indicate a history of volcanism rather than a primitive state. Mars is considered post-tectonic, likely influenced by its smaller mass, which affects the thermal dynamics of its core and mantle. The discussion raises questions about the definition of tectonic activity, suggesting that volcanic activity may be a more appropriate term for Mars, despite evidence of tectonic processes in its history.
cph
Might Mars serve as a pre-tectonic model for Earth? For example, no continents, no mountain building nor deep oceans? And does homogeneity of Valles marinaris, as opposed to Grand Canyon, suggest homogeneity for Earth's pre-tectonic environment?
I don't think so. You have the Martian dichotomy with the comparatively high, thick crusted, heavily cratered, old southern half and the younger, lightly cratered, thinly crusted northern plains.
You have strong residual magentism, with some evidence supporting early spreading ridges. There is the volcanism of the Tharsis bulge. And a host of other distinctive features.
I don't see these as being primitive in character - certainly not most of them - so it just doesn't speak to me as being an analog for an early Earth.
If you look at the magnetic signature of Mars you will note a spreading center (marked by reversals in Mars' magnetic field) was present prior to whatever event caused the Martian Crustal Dichotomy.
http://jmars.asu.edu/download
Bingo!
Not to mention Olympus Mons, the largest known mountain, which is an extinct volcano.
Mars is POST-tectonic, not pre tectonic.
Perhaps the fact that Mars is 40% of the mass of Earth might explain this fact, as the energy radiating from the Martian core and mantle had less mass to pass through on its way to outer space than on Earth, in addition to there (likely) having been less of such energy to begin with.
OOH!
Actually, I just thought of something.
What does it mean to be tectonically active?
Does it require plates to be crashing into one another, or spreading away from one another, or does it simply require my usual definition of "crunchy on the outside, gooey on the inside"?
Am I misusing the term, and should I really be substituting the term "volcanically active" for my customary usage of the term?
Anyways, this observation doesn't change my original statement, as the evidence of tectonic spreading on Mars indicated by Ophiolite and Shootist clearly exemplifies tectonic activity in the more usual sense in Mars' past.
Ophiolite:
Sorry! I didn't mean to ignore you, but I read through this thread rather quickly, and I didn't realize that my first post to this thread post (post #4) was, in some respects, a duplicate of yours, even though Olympus Mons isn't technically part of the Tharsis Bulge (though it's near enough that it might be a product of the same hot spot).
Hello, I’m currently writing a series of essays on Pangaea, continental drift, and Earth’s geological cycles. While working on my research, I’ve come across some inconsistencies in the existing theories — for example, why the main pressure seems to have been concentrated in the northern polar regions. So I’m curious: is there any data or evidence suggesting that an external cosmic body (an asteroid, comet, or another massive object) could have influenced Earth’s geology in the distant...
On August 10, 2025, there was a massive landslide on the eastern side of Tracy Arm fjord. Although some sources mention 1000 ft tsunami, that height represents the run-up on the sides of the fjord. Technically it was a seiche. Early View of Tracy Arm Landslide Features Tsunami-causing slide was largest in decade, earthquake center finds https://www.gi.alaska.edu/news/tsunami-causing-slide-was-largest-decade-earthquake-center-finds...
9K
