Does the mass of water increase when it is cooled to form ice?
In summary, according to the principle of mass-energy equivalence, the mass of water should decrease when it is cooled to form ice. This is because the internal energy of ice is less than water, resulting in a lower combined mass-energy. The answer of "increase" may be incorrect, as phase changes do not affect mass. The structural changes during the phase change may balance out the energy lost, but the overall mass should still decrease.
erisedk
374
If mass-energy equivalence is taken into account, when water is cooled to form ice, the mass of water should increase, decrease or remain unchanged?
E = mc2
Since the internal energy of ice is less than water, it's mass should also be less. This might be a completely wrong interpretation though because the answer says increase. I haven't really studied mass energy equivalence in much detail, I just know the basics from nuclear physics.
In any process where the internal energy decreases, energy must be liberated and pass to the surroundings - right? So, this energy has a mass equivalent given by E = mc2 . So, the mas must ...
Decrease? Because energy of the body decreased and went into the surroundings? Like in nuclear physics, the rest mass of the nucleus is lower than the mass of the individual nucleons because some of the mass gets converted into binding energy. So here since some of the energy has gone away, the mass should be lower, I guess.
Hi erisedk:
I think you are correct. The ice would have a lower combined mass-energy than the water. Can you post some context from where the answer that says "increase" comes from?
Regards,
Buzz
It was on an old practice test. That's okay though, the answers can be wrong sometimes. I think I'm correct too.
Likes Buzz Bloom
I think it is no change. E = mc^2 or m = E/c^2 where m is the rest mass. The rest mass is the mass measured by an observer in a reference frame where the object is at rest, and because phase changes don't affect mass, the rest mass should be constant. You'll measure the same mass as liquid and as ice. To account for the change in energy, perhaps the structural change balances the energy lost during the phase change.
Hi Red:
I am pretty sure you are mistaken. Think of what happens if you put an ice cube a 0 deg C into water at say 10 deg C. The ice melts and the water gets colder. The energy lost by the water melts the ice. Although it is not possible for thermodynamic reasons, if you ran the scenario backwards, some water would warm as the some other water freezes.
Regards,
Buzz
All forms of energy have an equivalent value of rest mass whether or not it is actually realized as 'mass'. The rest mass in an inertial frame is the same for all intertial observers yes but that does not mean it cannot be converted into energy within a given frame - by nuclear fission for example.
erisedk your conclusion is correct, the mass will be lower. One has to realize here that the amounts of mass equivalence are extremely small, E/c2 small!
Hi IAN:
I have learned over the past year from my participation in the PF that "mass" always means rest mass, except when some alternative and not generally current usage is specifically explained as to be what is meant. The term, "relativistic mass" is also generally no longer used for what seems to me to be a rather obscure subtle reason. I am not quite sure what is the preferred phraseology to replace "relativistic mass", but I think "mass-energy" is acceptable to mean the total mass equivalent of the sum of rest mass and kinetic (and possibly other forms of) energy.
Regards,
Buzz
Hi Buzz, I prefer to use 'rest mass' as it is unmistakable in its meaning. E2 - p2c2 = m2c4 being lorentz invariant.
Cheers,
Ian.
Likes Buzz Bloom
Here thermal energy decreases, therefore mass of water will increase.
What is mass-energy equivalence?
Mass-energy equivalence, also known as the famous equation E=mc^2, is a concept in physics proposed by Albert Einstein. It states that mass and energy are interchangeable and can be converted into one another. This equation has been proven to be true through various experiments and is a fundamental concept in modern physics.
How did Einstein come up with the idea of mass-energy equivalence?
Einstein first proposed the concept of mass-energy equivalence in his theory of special relativity in 1905. He realized that if the speed of light is constant, then energy and mass must also be related. He derived the famous equation E=mc^2 by combining the principles of special relativity and the law of conservation of energy.
What is the significance of mass-energy equivalence?
The concept of mass-energy equivalence has significant implications in various fields, including nuclear physics, astrophysics, and particle physics. It explains how energy is released in nuclear reactions, such as in the sun, and it also plays a crucial role in understanding the behavior of particles at high speeds.
Does mass-energy equivalence apply to all forms of energy?
Yes, mass-energy equivalence applies to all forms of energy, including potential, kinetic, and thermal energy. However, it is most commonly used in the context of nuclear energy and the conversion of mass into energy through nuclear reactions.
Can mass and energy be converted back and forth indefinitely?
According to the law of conservation of energy, energy cannot be created or destroyed, only converted from one form to another. This means that mass and energy can be converted back and forth indefinitely, but the total amount of energy remains constant.
