Mass on spring rotates - what happens?
  • Thread starter Thread starter ambroa
    Mass Spring
When a heavy object is hung on a spring and the spring is rotated, the dynamics involve centripetal force and the spring's tension. The centripetal force required for circular motion is given by mv^2/r, where m is mass, v is velocity, and r is the radius of rotation. The vertical component of the spring force balances the weight of the object. To find the total spring force, one must calculate the resultant of the horizontal and vertical components. Finally, Hooke's law can be applied to determine the extension of the spring based on the resultant force.
ambroa
hi,
what happens, when I hand on a spring a heavy object and then we'll rotate the spring? I've tried to write down some maths for it but I don't know anyway...
ambroa said:
hi,
It's the same as rotating the object hung on a rope: if swung in a horizontal circle at constant speed, v, the centripetal force is mv^2/r, which is the horizontal component of the spring force, and the verticlal force component of the spring force is the weight of the object. Once you calculate the resultant spring force, use Hooke's law to determimne its extension.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
