Mass sliding down incline with spring
A 3kg mass slides down a 30-degree incline and compresses a spring after traveling a distance d, with the spring constant k at 400 N/m. The problem requires finding the initial separation d between the mass and the spring. The discussion suggests using energy conservation principles instead of force equations, focusing on the work done by gravity and the spring. It emphasizes calculating the work done by gravity over the total distance traveled, including the 0.2 m of spring compression. This approach simplifies the problem by avoiding complex kinematic equations.
fireearthair8
A 3kg mass starts at rest and slides a distance d down a smooth 30deg incline, where it contacts an unstressed spring. It slides an additional 0.2 m as it is brought momentarily to rest by compressing the spring (k=400N/m)
What is the initial separation d between the mass and the spring?
F=ma
Vf = Vi + at
Us = 1/2kx^2
Ug = mgh
K = 1/2mv^2
I'm not sure how to approach this problem yet. I know that you need to find the Vf, using mgsin30 as the acceleration and Vi=0.
Hi fireearthair8,
They give you Vf in the problem statement (the final velocity of that part of the motion they are referring to). What is it? Now that you also know the final speed, does that help you know what approach to use?
Welcome to PF!
fireearthair8 said:
F=ma
Vf = Vi + at
Us = 1/2kx^2
Ug = mgh
K = 1/2mv^2
Hi fireearthair8! Welcome to PF! :smile:
Hint: forget F = ma and Vf = Vi + at.
You can do this just using energy (and d = h cos theta). :smile:
another hint:
find the work done by the spring, then compare that to the work done by gravity, which acts along the distance traveled without before touching the spring as well as the .2 m after it comes in contact with the spring.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
