The Function of the Ceramic Disk in an HP 5971A Mass GC-MS
The discussion centers around the function and movement of a ceramic disk located between the ion source and the quadrupole in an HP 5971A mass GC-MS system. The ceramic disk is designed to allow for alignment adjustments between the ion source and the quadrupole, which is crucial for optimal performance. Although the disk should move freely to facilitate this alignment, the user experienced issues with the disk being stuck and only able to rotate after some effort. The presence of screws around the disk suggests that it is secured in place after adjustment. The movement of the disk appears to be limited to rotation around the central hole where the ion source fits, and it is speculated that this movement is primarily intended for servicing purposes to ensure proper alignment before finalizing its position with the screws.
LtStorm
Not sure where exactly this should go, as it's a hardware question rather than a homework problem or question about the theory behind it, so, sorry if it's the wrong place.
But, I've been working on getting an old HP 5971A mass GC-MS up and running over the past semester, and there's a part of the ion source I don't understand the function of.
It's a quadrupole machine, and apparently there's a ceramic disk between the quadrupole and the ion source. The front nose of the ion source fits through a hole in the disk to point down the quadrupole.
I watched a video explaining how to clean the machine, and in the video it explicitly notes the disk should be able to move freely to keep alignment between the ion source and quadrupole. What I don't understand is how disk moves. The one in the machine I was working on was actually stuck in place apparently when I first replaced the source after cleaning it. After some fiddling, the professor I work with and I got the disk to turn some, but it still sticks.
I don't see any mechanism that could make the disk move, and it has a groove around its edge that little screws are pointed into apparently to keep it in place. As noted, the nose of the ion source goes through a hole at the center of the ceramic disk, so the only motion I can see the disk being able to make is rotating around that hole, but...I don't understand how it does this, or why it needs to.
Anyone happen to know? No one I know has yet been able to explain it to me.
Chemistry news on Phys.org
It probably is moveable only during servicing. The fact that it can move easily indicates that the plate is installed with the hole 'normal' to the axis of the ion source. Moving freely indicates that it isn't cocked or wedged into place before fixing its position with the adjustment screws.
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
