Solve Mass-Spring Model: Find Shear Force
The discussion focuses on solving a mass-spring model to determine the shear force produced by a half-full water tank on a building. The parameters provided include a mass (m) of 500 kg and a stiffness (k) of 1000 N/m. The primary method discussed is the Transfer Matrix Method, although participants also consider using the period of oscillation formula T = 2π√(m/k) to calculate the maximum shear force, ultimately arriving at a value of 707.1 N, while the exam answer states 2000 N. The conversation emphasizes the need for additional information regarding the tank's dimensions and shape to fully resolve the problem.
  • Understanding of mass-spring systems and oscillation principles
  • Familiarity with the Transfer Matrix Method in structural analysis
  • Knowledge of shear force calculations in engineering contexts
  • Basic grasp of Housner's theories on fluid-structure interaction
  • Study the Transfer Matrix Method for dynamic analysis of structures
  • Learn about Housner's paper on fluid-structure interaction and its applications
  • Explore eigenvalue problems in the context of structural dynamics
  • Investigate the effects of tank shape on shear force calculations
Engineering students, structural analysts, and professionals involved in fluid-structure interaction studies will benefit from this discussion, particularly those focusing on dynamic response analysis of tanks and similar structures.
toolpusher123
A half-full water tank mounted on the top of a building is modeled as shown below. Find the shear force it can produce?
m = 500 kg
k = 1000 N/m
model: https://app.box.com/s/qke2kbwag2mp9a23kkqq
Transfer Matrix Method:
Point & Field Matrices: https://app.box.com/s/0gmyi1hqaecp1hfjd3f3
Rearranged model: https://app.box.com/s/nycu9csciavufusnlnfz
I'm unsure if I should use this method; find T (period of oscillation), use T to find force 'F'.
working 1: https://app.box.com/s/he5ji206c1c8s76lrf09
Or if I should use 'Transfer Matrix Method'. If I should use this method, how should I start?
Your first figure looks nothing like a tank of water. I don't see the connection at all. Maybe you could elaborate?
It's not 100% clear to me either, but if you look at page two of the attached .pdf below. It seems that what I've been given is a simplified model where the mass of the water (m) is 500 kg & the equivalent stiffness of the building is (k) 1000 N/m. It then asks me to find the shear force?
pdf: https://app.box.com/s/ftdnwffvx3y0wf9kl44f
The method I've been studying recently is 'Transfer Matrix Method' but this requires an applied force over a period of time (sinusoidal excitation force). But as this problem doesn't have one, the only way I can think of to resolve it is just to use T = SQRT(k/m), F = 2*pi/T. The problem comes from an old Engineering Analysis Paper MEng/BEng (Hons) but it's only worth 4 marks. Just not sure where to start with the limited info??
Ah, now we are getting somewhere! Your first post said exactly nothing about horizontal ground motion. You really need to help by telling us what the problem of interest is here.
If you read the Housner paper, I think you need to consider most Fig. 3. You need to use your given data to evaluate M0, M1, k, k1 etc., according to what Housner has described in his paper. This will enable you to write an approximate equation of motion for the system. Do you know if your tank is circular or rectangular in plan section?
Basically the question is asking you to apply (and slightly extend) Housner's ideas. This is a very good problem, and an opportunity to learn some very practical engineering analysis.
By the way, T is the period, not the natural frequency!
Yes you're correct, T (period of oscillation) = 2*π√m/k. Therefore F (max force produced) = (2π/T)*m. I'll have to σo through the paper properly & post once I have a more thorough understanding. Thanks for your input, back asap...
Stiil pretty much stuck with this one? Using Housner paper the max shear force that can be produced by the half filled tank is; T = 2*π√m/k ∴ T = 2*π√500/1000 = 4.443 seconds. This is the period of oscillation therefore shear force F = (2*π/T)/m = 500/(√500/1000) = 707.1 N. The answer given in the exam paper is F = 2000 N.
From post #4, I can't evaluate M0, M1, k, k1 as there is no further info given i.e. no dimensions, displacement, shape of tank etc. Only mass (m) & equivalent stiffness (k).
I've thought about turning this into an eigenvalue problem & using Lagrange's eq's but with the limited info I'm not sure how to proceed?
  • If anyone has any ideas please post...
  • · Replies 45 ·
