Staerke
- 12
Three balls are attached to a rod. Ball one has mass 0.614 kg and is 14.0 cm from the pivot. Ball two has mass 0.634 kg and is 25.0 cm from the pivot. Ball three has mass 0.729 kg and is 35.0 cm from the pivot. The rod has length 86.0 cm and mass 0.486 kg. Calculate the rotational inertia of the system (the size of the balls may be neglected).
THEN
If the system starts to spin around its pivot point with an angular speed of 5.45 radians per second, what is the kinetic energy of the system?
I'm stuck on the first part, I=(1/3)ML^2
I know since it's a pivoting rod it's (1/3)ML^2
What I've done is this:
(1/3*.14/86*.25/.86*.35/.86) = .00642
Basically adding up the fractional lengths for each mass.
Next I add up the masses including the mass of the rod and multiply it by the number above and the length squared:
.00642*((.614+.634+.729+.486)*(.86^2) and get .011694 which is obviously wrong.
I have absolutely no idea what to do here, so I'd really appreciate a breakdown of how to do this (without calculus, we're not using calculus in my introductory physics class and honestly it will just confuse me)
Thanks for any assistance.
