Mastering Trigonometry: Graphing Sinusoidal Voltage with v = 6sin (314t + pi/2)
  • Thread starter Thread starter will.i.am2
    Trigonometry
The sinusoidal voltage function v = 6sin(314t + π/2) has an amplitude of 6, derived from the maximum value of the sine function multiplied by 6. The time period can be calculated using the formula T = 2π/f, where the frequency f is determined from the angular frequency of 314 rad/s, resulting in a time period of approximately 0.02 seconds. Users discussed the importance of using radians for calculations, clarifying that sin(π/2) equals 1, leading to the maximum voltage of 6. Proper understanding of trigonometric functions is emphasized for accurate graphing and analysis. Mastery of these concepts is essential for graphing sinusoidal functions effectively.
will.i.am2
A sinusoidal voltage is represented by the formula v = 6sin (314t + pi/2). Sketch the graph on the graph paper provided for values of t from 0.0s to 0.04s and show on the graph the values of
• the amplitude
• the time period
and show how the frequency of the waveform may be determined from the graph.
can i have a small hint on finding the amplitude and the time period?
• the amplitude
• the time period
and show how the frequency of the waveform may be determined from the graph.can i have a small hint on finding the amplitude and the time period?
If you know calculus, the amplitude will be the value of v at the time ##t_0## such that ##\left.\frac{dv}{dt}\right|_{t_0}=0##.
If you don't know calculus, what's the maximum value of the sine function and what does that imply about the magnitude of ##6\sin(\xi)##?
Mandelbroth said:
If you know calculus, the amplitude will be the time ##t_0## such that ##\left.\frac{dv}{dt}\right|_{t_0}=0##.
No. The amplitude is not a value of ##t##.
In other words, the amplitude.
@will.i.am2: You are required to show an attempt at solving the problem to receive help.
Sorry. I misspoke. The amplitude will be the value of v at ##t_0##. I fixed my post.
v = 6sin (314t + π/2)
v = 6sin (314(0) + 3.14 /2)
v = 6sin (0 + 1.57)
v = 6sin(1.57)
v = 0.16
v = 6sin (314(0.01) + 3.14 /2)
v = 6sin (3.14 + 1.57)
v = 6sin(4.71)
v = 0.49
v = 6sin (314(0.02) + 3.14 /2)
v = 6sin (6.28 + 1.57)
v = 6sin(7.85)
v = 0.81
v = 6sin (314(0.03) + 3.14 /2)
v = 6sin (9.42 + 1.57)
v = 6sin(10.99)
v = 1.14
v = 6sin (314(0.04) + 3.14 /2)
v = 6sin (12.56 + 1.57)
v = 6sin(14.13)
v = 1.46
i think maximum value of sin is 6 but i don't know what's it implying on the amplitude of 6sin.
I think the maximum of sin is 1. Try graphing it. And set your calculator to radians, not degrees.
i have done it in rads only. & how can it's be 1?
What does the value of y = sin(x) look like. What max/min values does it have ? What about y = psin(x) where p is some real number. What are it's max/min values ? How does this relate to the equation you were given ?
If you take sin(1.57) in radians, you should get very close to 1. 1.57 is almost pi/2.
why have you taken sin of half pi? I still didn't get it.
v = 6sin (0 + 1.57)
v = 6sin(1.57)
v = 0.16
I'm trying to tell you v=0.16 isn't right because your calculator isn't in radian mode. sin(1.57) should round off to 1.00, so 6*sin(1.57) should be 6.
This is in the wrong forum. This is neither calculus nor beyond. It's pre-calculus.
v = 6sin (0 + 1.57)
v = 6sin(1.57)
v = 0.16
How did you arrive at this value... Let's try it
we have
v = 6sin(314t + \frac{\pi}{2}}
verbally stated v = 6 times the sin of 314t + \frac{\pi}{2} radians.
So at time t = 0 we have..
v = 6sin(314(0) + \frac{\pi}{2})
which gives
v = 6 sin( \frac{\pi}{2})
In other words to get v at t=0 we have to multiply the sine of \frac{\pi}{2} radians by 6.
\frac{\pi}{2} radians in degrees is 90 degrees, the sine of which is 1 . So what then happens when you then multiply 1 by 6 to get the final result for v ?
Your calculations are screwed up. As someone else pointed out, you appear to be using a calculator set to degrees but you are providing radians. Either switch the calculator to radians or, convert the radians to degrees and then compute the sine.
yes, you guys are absolutely right & my mistake I wasn't doing in rad.
it is equal to 6 then the amplitude would be 6 - (-6) / 2 = 6
Given that -1 <= sin(x) <= 1, it follows that -6 <= 6 sin(x) <= 6 (just multiply each part by 6).
PS. It helps to learn all you can about these trig functions.
