Mathematica help union/intersection of 3d plots
  • Context: Mathematica
  • Thread starter Thread starter yzhang33
    3d Mathematica Plots
This discussion focuses on performing union and intersection operations on 3D plots using Mathematica's RegionPlot3D function. The user successfully utilizes the Show function to display the union of two plots, A1 and A2, and later discovers the use of the '||' operator for unions. The intersection of two regions can be computed using the '&&' operator within RegionPlot3D. The key takeaway is that both union and intersection can be effectively managed using the appropriate logical operators in Mathematica.
  • Familiarity with Mathematica software
  • Understanding of 3D plotting concepts
  • Knowledge of logical operators in programming
  • Experience with RegionPlot3D function in Mathematica
  • Explore the use of logical operators in Mathematica for advanced plotting techniques
  • Learn about combining multiple RegionPlot3D outputs effectively
  • Investigate the implications of using Show versus RegionPlot3D for unions and intersections
  • Review the Mathematica documentation on RegionPlot3D for additional functionalities
Mathematica users, data visualizers, and researchers working with 3D graphical representations who need to perform union and intersection operations on spatial regions.
yzhang33
I want to do the following:
Say I have 4 RegionPlot3D plots, namely A1 A2 B1 and B2. Each of those four plots are region plots so they occupies some kind of region inside the same 3d space.
First I want to find and display union of A1 and A2, call it A. Then find and display union of B1 and B2, call it B. Lastly, I want to find and display intersection of A and B.
Somethings that I have tried:
1. I can use Show[A1,A2] to graphically find the union of A1 and A2, but after I got A and B. I can't use the Show function to find intersection.
2. I can directly use RegionPlot3D to find intersections of two plots by naming the regions region1 and region2. I can use do RegionPlot3D[region1 && region2...] to do it. But I can't find unions using this method.
3. If my goal is first do intersection, then do union, I can use above two method to do it. But my goal is first do union. So if I use, it doesn't really tell me what region does the union results in, it just displays it.
If you can do RegionPlot3D[region1 && region2...] for intersection
then why can't you do RegionPlot3D[region1 || region2...] for union?
http://reference.wolfram.com/mathematica/ref/RegionPlot3D.html
right right. I just found it out there is a || operator as well. Thank for the reply.
