What Careers Combine High-Level Mathematics and Programming?
Mathematical neuroscience, computational neuroscience, and neuroimaging are highlighted as promising fields that combine high-level mathematics and programming. Key mathematical areas relevant to neuroscience include nonlinear dynamics, differential equations, statistics, and neural networks. An applied mathematics degree is recommended for better job prospects, with additional coursework in computer science and engineering being beneficial. Careers in statistics are noted as a viable option for those with an undergraduate degree, although pursuing a master's may enhance job opportunities. The discussion emphasizes the importance of aligning educational paths with career goals in these interdisciplinary fields.
Kevin_Axion
I just have a few quick questions on mathematical neuroscience. What are the branches of mathematics that are used frequently in neuroscience? And finally, is it common for math majors to enter neuroscience in graduate school?
Yes, I'm thinking about it micro, now don't pester me!
Mathematics news on Phys.org
Hi Kevin! :smile:
This might not be the best forum to ask this on, but I did a little research. The fields "mathematical neuroscience", "computational neuroscience" and "neuroimaging" are very hot fields. Take a look at following links:
http://www.whydomath.org/node/HHneuro/index.html
http://neurotheory.columbia.edu/~ken/math-notes/
Apparently, in uses nonlinear dynamics a lot (which is very interesting!). In any case, you will want to do an applied mathematics program with focus on differential equations, statistics, analysis, Fourier analysis, neural networks,...
I have a bit of experience in neuro-imaging and image-compression, but it is a very interesting field. It uses quite a lot of deep and pure mathematics (mostly analysis, functional analysis, etc.). I've had the honor of following a class of one of the prominent figures of image-compression, professor Daubechies. She did a double major in mathematics and physics in my university, and worked in quantum mechanics for a while. But she then switched to image compression and did fabulous work there. So I guess that an applied math/physics degree does prepare you sufficiently for an applied carreer.
If you want to consider this path, then an applied mathematics degree is useful. Taking classes in computer science, physics and engineering is very advisable. Be sure to find a school were applied stuff is popular, though, as many pure mathematicians can get bogged down in theoretical details that don't matter...
As for job prospects and whether mathematicians really have a chance of becoming neuroscientists, you will probably have to ask people working in the field. I don't know if there are such a people on PF...
In another attempt to convince you of the usefulness of mathematics: take a look at the site
http://www.siam.org/careers/thinking.php
it gives all kind of possible careers of applied mathematicians. There are all kind of job opportunities out there, and very likely some you will find interesting.
I said applied math and your response was "no, pure mathematics only" :wink:. Although I was reluctant towards both due to job opportunities so thanks! What is better for preparation then, an applied mathematics, mathematical physics or pure mathematics degree?
I was joking :biggrin: You mustn't take me all that serious about these things (certainly in chat). Just do what you think you'll like! :smile:
I do like math a lot it's just a matter of job opportunities. I also very much enjoy neuroscience which is a growing field so I'm trying to draw a connection which you have helped me with so thanks!
Kevin_Axion said:
What is better for preparation then, an applied mathematics or mathematical physics degree?
I would lean towards applied mathematics if you want the better job opportunities. The thing about applied mathematics is that it is used in so many fields, not only physics. Image processing, data mining, optimization are all studied by applied mathematics. Mathematical physics might limit you to physics thingies. (of course, this is a mathematician speaking).
Also, I want to make it clear that I have absolutely nothing against applied mathematics. These are very powerful and interesting fields. I wish I knew more about them...
Thanks micro, you're always of good help!
Gonna hijack this thread but i have a question for micromass. If i want to do a job that requires a good level of high mathematics but also want to program with these mathematics, what kind of jobs are out there? By high level mathematics, i mean just some undergraduate courses on stochastics, analysis, data mining, etc..?
I'd also like to take knowledge in computer science (at the undergraduate level for 3rd and 4th year classes) and apply it as well.
Basically i want a job that optimizes an undergraduate degree that has specialization in statistics and computing. Possibly without taking a masters degree.
You really shouldn't me for such a things, I don't think I'm very qualified to give a decent answer. You should ask twofish-quant, he knows quite a lot of such a things.
But anyway, I kind of doubt that an undergraduate degree alone will get you what you want. I'd consider doing a masters degree.
I think there really are lots of jobs out there that you describe. Basically every job as statistician will give you what you want. You only need to choose what kind of statistics interests you the most. Also see this: http://www.siam.org/careers/thinking/fields.php
People with knowledge of statistics are really in high demand, so you should find a job fairly easily.
