Matrices of simple face and cubic centered cubic lattice
Petar Mali
S=<br /> \begin{bmatrix} a &amp; 0 &amp; 0 \\ 0 &amp; a &amp; 0 \\ 0 &amp; 0 &amp; a \end{bmatrix}<br />
for simple cubic
I=<br /> \begin{bmatrix} -\frac{a}{2} &amp; \frac{a}{2} &amp; \frac{a}{2} \\ \frac{a}{2} &amp; -\frac{a}{2} &amp; \frac{a}{2} \\ \frac{a}{2} &amp; \frac{a}{2} &amp; -\frac{a}{2} \end{bmatrix}<br />
for volume centered cubic
F=<br /> \begin{bmatrix} 0 &amp; \frac{a}{2} &amp; \frac{a}{2} \\ \frac{a}{2} &amp; 0 &amp; \frac{a}{2} \\ \frac{a}{2} &amp; \frac{a}{2} &amp; 0 \end{bmatrix}<br />
for face centered cubic
I don't see any logic for this matrices? How can I get this? I can axcept that simple is P because minimum distance between neighbors is a. But But what with the other two matrices?
How are these matrices defined?
Those matrices have the lattice vectors as rows (or columns, since they are symmetric). If you have a cube with side length a and one corner at the origin, then integer combinations of those vectors give you the lattice points. I'm not sure what your question is. Look at FCC. You have one atom at each corner, so points like (a,0,0) and (0,a,0), etc. Then at the center of each face, so points like (a/2,a/2,0) and (a/2,0,a/2). Those points come from adding those vectors together.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
